Topic: FTCF "Not your average" 5.0 build up, help wanted! (Read 3973 times) previous topic - next topic
There should be some of those valve covers used on ebay.
I have seen finned "Bronco" valve covers. Would be cool.
If you were closer I'd do the heads for you. Email me if you want some tips.
I agree with the efi for offroading, but I have done a lot of carbs for offroadracing in the past. Just more HP than you are planning.
Good luck. One of my dreamcars is a pre-'77 Bronco
Quote from: TurboCoupe50;162941
Edit... Nope the '86 was 285 ft lb @ 3000, while the '87-'92 is 300 lb @ 3200... The '93 is only rated at 275 ft lbs @ 3000, which basically proves on a stock engine, the SD system makes more HP...
The 1993 engines were the same as 1992 with the only difference being the change over to hypereutectic pistons.
The reason for the change in the rating for 1993 was that Ford revised their internal testing procedure for rating an engines power to better reflect a more realistic engine output. Previously the rating was obtained by hand assembling an engine with production parts and then using this one engine for the test.
1993 and later testing uses randomly selected engines off of the production line get the power rating.
Brent
:cougarsmily:
One of 1,246 built
i have some V/C but i doubt they would fit under a efi intake, they are for a carb motor, old set of mickey tompsons. if you interested let me know, but like i said not sure if they will fit
Sounds like you have most of the info you need.
Additionally, the truck efi upper is an excellent low speed performer. The so roller cam, supposedly, is the same spec as what is in my 93 Bronco. Which may be a flat tappet cam in a roller block? It's never had any major engine work, 189K.
It definately has speed density, so firing order, and 19lb injectors. I believe it has bank fire injection. It has been a great truck!
That could be a possible computer choice with the so roller cam and 19#'s
 Mike
I found an 89 LSC in a local yard. If I can get it cheap enough, I'm going to grab the upper/tb/egr, injectors, ecu, and exhaust manifolds. I dunno about trying for the cam. They are trying to talk me into the whole motor for cheap...
That would pretty much get you set. Don't bother with the harness form the Mark VII. The Sport has a much easier to work with harness for the swap.
hows the rest of the lsc? haha
Gold on tan leather and garbage. They have 2 of them though, the other one is Gunmetal on Red IIRC?
if you can get the driversideplastic speaker mount in the door ill buy it off you. if you wanna and if its there and in one peice
o and a passenger side tail light
o and those V/C i was talking about here they are!
If your looking for a little more convertor, When my current one comes out for the 2nd upgrade you can have mine.  4000 miles on it.....
Sweet! I'll take it!
daboss,
No on the VC's, we are definitely sticking with EFI. Have a pic of the piece you need? I can drop by the yard on Thursday-ish next week.
they are not tall ones, my dad swapped them cause they wouldnt clear roller rockers, ill have to measure to find out if they would fit. and no, i have no picture, im not home. it holds the speaker in the door, its behind the door panel. and you know what a tail light is haha
