Topic: Keypad Entry? + Illuminated Locks (Read 2735 times) previous topic - next topic
I have all of the 84 documentation. Hopefully it is close enough to 83. I will will try to post some info for you in the next couple of days.
I am not up to speed yet on using my new ISPs free web space. My scanner went away when I upgraded my on-line PC to XP. I put my scanner on my old 98 PC and put the pictures on a usb flash drive to move them to the XP. Anyhow I almost have all the kinks out of this proceedure.
Big but legible.
If you want the pictures of anything else on the component location list, let me know.
You will need the factory-programmed code for that unit you got from the jy. It is a five digit code and, according to the shop manual,  should be inside the trunk lid. I do not know if the code is on the module itself.
