Topic: H/L bracket needed (Read 352 times) previous topic - next topic
H/L bracket needed
I have a 87 Bird and am looking to replace the rt side h/l bracket. The black plastic piece that the housing mounts to. Replaced my h/l hsgs over the weekend and noticed one tab is cracked so figured I would find a replacement before it breaks. Thanks
H/L bracket needed
Before you go and replace that bracket you might want to go ahead and try some two part epoxy to fix it up. If it's just cracked and you still have the other piece a two part plastic epoxy will effectively make it one piece again. At least that's what I did on mine.
