Topic: Newbie 12 sec T-bird (Read 6980 times) previous topic - next topic
This is a great car, I love it. Motor looks well put together, and almost the setup I want when I'm "done" with mine one day
Nice sleeper. Now I just need to fix my front brakes, rehook up my starter, get some DR's or slicks......oh and maybe a cam before I get bumped off any more. :hick:
Quote from: Innes;161342
which cam are you running whats the RPM range
It is a Trickflow 224/232-543/563 it is a mid to top end cam,very lumpy:D
Finally got the k-member in look at the motor mount it has been rewelded 4 times due to cracking:D
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
more pictures
now just need to buy new tie rod ends,drivers side brake line and some strange struts then I will be ready to go back to the track
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Nice... Looks like ya got yourself a real hot rod there...
for your k-member kit does it just come with front coil-overs only or back coil-overs only or both front and back? also does it break easy or strong when put in?
