Topic: Terrible gas milage 2.3T (Read 4477 times) previous topic - next topic
Quote from: bhazard;160679
ummm TPS is NOT "temperature sensor"
tps is throttle position sensor my bad..
its the ECT you want then.
:birdsmily:
How much boost are you running?  What injector size do you have?  What is your base fuel pressure without boost?
leaking injector o-rings?
Well injectors are not leaking.
Im running 18lbs of boost stock injectors ans stock fuel pressure.
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
I would say run codes and see if anything pops up.  Is the orange ground wire connected to the turbo inlet housing?  Try and keep the RPM's below 3K so the computer stays in closed loop.  Coolant sensor for the ECU reading correct?
Mike
Mike
You might want to check your fuel pressure regulator. Pull the vacuum line off of it, if you smell gas and you shouldn't, it is a bad regulator and would cause a rich condition and bad fuel mileage. Hope this helps...Tommy
