Topic: Good sources for a 12V switched signal under the hood (Read 1935 times) previous topic - next topic
Does anyone know, off the top of their head, of any good 12V switched sources under the hood besides the coil?
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Coil and everything else switched is fed from the red wire with green stripe... It's a double feed from two switch sections that are connected together... So basically you can pick up the R/G wire about any place it's convenient... Same circuit also feeds several fuses in the panel...
If you do pull power from the coil wire use a relay on what ever device so you don't pull excessive current from the coil.
I never take power off the coil, I only use the 12V switched to trip relays or if something calls for it (like gauges), which I can't imagine use much power anyway.
Garrett H.
Exhaust sound clip
Another clip
Quote from: CougarSE;160218
some people have a nack for saying so much with so few words.  amazing.
Quote from: jcassity;160448
Make me think other people know how to think too.
What do you mean by that?
You got right to the point and didn't leave anything out.
Heh...  ok.
:confused:
You'd really have to elaborate to say it in too many more words than that anyway.
Garrett H.
Exhaust sound clip
Another clip
