Topic: Last valvetrain ? I promise... (Read 3116 times) previous topic - next topic
Alright, so now I have everything to put her back together.
Got a question regarding valve stem seals...
What is this and does it need to be on there? It was on my valves when I pulled them out.
...and is the intake seal supposed to fit snugly over the valve guide just as the exhaust seal does?(Yes, I know they aren't over the guide in the picture)
Bump, someone shed some light on this for me.
At first I thought it was a spring shim(to increase pressure) but it looks smaller...
You using a mix of seals??? If so aren't they reversed??? You want the Perfect Circle on the intake, so it doesn't suck oil past the guide...
Quote from: TurboCoupe50;159816
If you mean a mix of seals, by seperate for intake and exhaust, then yes.
The blue ones are for the exhaust and the black are for the intake.
What do you mean Perfect Circle?
No, it's not a spring shim, these don't have any.
Alright, well I've read that people use the Perfect Seal style seals for the intake and the umbrella for the exhaust so that is what I will be doing. The 'Perfect Seal" style ones were in the box marked for the exhaust side however.
Now, I am just wondering where the umbrella style sets and what the f^ck that o-ring thing is for...
id use the good pc seals on both sides (intake and exhaust)
and make sure to use the install tool or the keeper grooves can damage the seals.
a little lube on the stems is manditory or you will be siezing valves.
yeah, like tom said, you have it backwards.  the cap type seals go on the exhaust and teh snuggly round blue one goes on the intake.
some kits will come with too many of the hood types so dont be worried about coming up with 8 extra of those.
it would be nice to have the blue type you have there on both stems because you really dont get the chance to do that later on unless your good at undoing the sprint / cap/keepers with the head still on.
Did the shop ask you to also send your valves to them?  that would have been nice of them to determine if the guides had excessive wear and would make you want to use the blue types on both stems.
Also,, get a little bottle of red lithium grease.  Your gonna want to coat the valve with that stuff cause those valves are going to be rubbing dry against the guide until oil arrives.  That can equate to probably 100 or more cycles which is a lot of wear.
As far as that roundy thing a ma jig,, ive never seen that before,  Maybe if you wire wheel it off, you might find some information on it.  Were those located under the lower spring cup?
Quote from: jcassity;159835
Did the shop ask you to also send your valves to them?  that would have been nice of them to determine if the guids had excessive wear and would make you want to use the blue types on both stems.
No the shop didn't. It was more of a performance shop for race stuff so he wasn't to fond about doing mine.
I'm lapping the valves myself.
Does anyone know where that o-ring comes into play and where the hood/umbrella type seals seat?
i edited my post which i often do.
the round thing ive never seen before and likely you dont need em unless they are located under the lower spring cup.  Clean em off and see if they are marked with an thickness.  If they are, then its likely someone else shimmed the springs.
for the hood type seals,, stick them on each exhaust valve stem.
stick the snug blue ones on the intake.
get some red lithium.
if you wanna freshen up your seats,, get or borrow some of these,,,,,,
made by neway
Quote from: jcassity;159845
made by neway
Do I slide the hood style ones over the guide?
I am freshening up the seats with valve grinding compound and working them in.
just stuff them over the valve stem,,, as the valve opens and closes,, they will relocate themselves to thier final resting spot anyway cause the valve slides up and down.
install your hood types on the stem,,and get em over the guide as well..
Quote from: 88XR7;159850
also, if your lapping by hand, eyeball your surface you are cutting and stop when the ring around the valve is nice and even all the way around the valve.
there should be three angles visible but your likely to only see the 45deg one.
you can lap one at a a time then take out the valve, wipe off the compound and inspect the area i mentioned.
my heads were a bitch cause my 1.94's were soooooooo  close to the spark plug hole.  Caused me a lot of problems in the beginning. Im still down due to other more responsible things to do with a few spare dollars at the moment.
please dont forget the red lithium i mentioned,, that stuff is more sticky than pine sap and wont wear off quickly.  your gonna need that protection on those valves since they are bone dry now plus your adding grit and sandy substances to the mix.
Also,, if any ,, and i mean any valve is not so easy to get in or was sort of a bitch to get out,, that means the rocker mushroomed the end of the valve just enough to increase its diameter up where the keepers are.  If you noticed any of that then before you install them, use a real fine flat file to "debur" the valve stem up on the end around the edges.
ok
and another note on quality to check your guides the shade tree mechanic way.
get some real thin oil and coat the valve stem and guide.
stuff the valve up in the hole.
now,
push the valve stem down till its flush with the gude.
press your finger down over the guide and valve stem
now with your finger over top of the guide hole and stem reach and pull on the valve itself
start to pull on the valve while holding your finger good and tight over the guide hole
now,, let go of the valve end
the valve should "boing" or get sucked back up into the guide.
what you just did is check the guide for good clearance.
if the guide was worn, then the valve will not suck back up into the guide.
thats a shade tree way of checking and most shops do that as well if they want to.
the reason why i said to use thin oil such as 3in1 and such is this,, If your valve was sucked back in (holding a good vacuum) using thin oil then its gotta be good enough when regular motor oil is in there.
Quote from: jcassity;159859
ok
now,
Wow, great stuff to know man!:hick:
Quote from: jcassity;159857
Yeap, I've noticed a big difference on the total area that it is seating, it is visibly noticeable by where the area is being ground.
ALL of my valves were easy to get out, nothing tuff;)
Would regular lithium or just engine assembly lube work?
