Topic: MINT 20th Anniversary Cougar (Read 1382 times) previous topic - next topic
http://philadelphia.craigslist.org/car/355410234.html
I want it! :cougarsmily:
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
when did these cars come with heated seats? never knew that was an option
It (heated seats) was only offered on the 20ths. Not even an option (as just about everything was offered as "standard" - the only options available on the cars were:
[LIST=1]
  • keyless entry (the keypad)
  • Automatic Temperature Control
  • and the moonroof.
The moonroof, of course, is the most "rare" of the three options on these cars. Most 20ths I have seen usually have either the keyless entry or the ATC, or both.
Ahem... ;)
REGULAR PRODUCTION OPTIONS
45A Traction-Lok axle
573 Automatic temperature control
91H Power antenna
47J Illuminated entry system
144 Keyless entry system
21B Power moonroof
NOTE: 47J and 144 required to be ordered together.
LIMITED PRODUCTION OPTIONS (DEALER INSTALLED)
Engine block heater
Front license plate bracket
http://www.coolcats.net/fox/20thanniversaryoptions.html
My bad, Eric - I was just going by what the salesman said 20 years ago. I was unaware of the Traction-Loc, power antenna, or illuminated entry as options. Mine's got everything but the sunroof, and I thought that was the only thing she was "missing."
Now, I am actuallly not sure about the Traction-Loc axle. Waht is the easiest way to determine if my car is equipped with tat option or not? Thanks/
Royce, I'm just bustin' your nuts. :punchballs:
What you said about there only being three options, EVERYONE used to say. I've heard that myself for 20 years. It was just a common-knowledge thing for some reason. But once I found the dealer order page for the 20th model, it became clear that there were more than 3 options for the car. A "stripped" 20th is still pretty loaded up. But to get the ultimate factory 20th, you'd have to have ordered everything on that list.
Your axle code is on your door tag; should be above AX. List of codes here:
http://www.coolcats.net/tech/general/axleinfo.html
or just spin um up!!!!!
so he saying heated seats, and i was right in assuming those were never offered?
Quote from: daboss351;157584
He is saying that they were standard equipment on the 20th, and were not even offered as an option on Cougar LS or XR-7.
Brent
:cougarsmily:
One of 1,246 built
