Topic: dash (Read 601 times) previous topic - next topic
dash
I'm looking for a dash for my 84 bird. prefer black or blue if in good condition. If not color does not matter I will put a cap on it. I just need the top w/the pad:birdsmily:
[SIGPIC][/SIGPIC]84 Thunderbird/ 408ci windsor, vic jr. heads,super victor intake/ camshaft ground by Cam Research/Pro Systems 950 cfm/msd ign./hooker super comp headers/Full manual C4, ultimate converter concepts 5000 stall/ 8.8 w/4.33 gears,Moser 35 spline axles and spool/double adjustable upper and lower control arms/Strange drag shocks and struts/10 point roll cage/weld drag lites/28 x10.5"/UPR k member and control arms/coil overs. 1/8 mile to date 6.39-60' 1.35 "NO POWER ADDERS"
dash
Do you know if the 83-86 dashes are the same as the 87-88 dashes? I've got a near perfect blue dash out of an 87 TC for $150. You don't say where you are located, so it may not matter because I wouldn't be able to ship it. Thanks.
1987 Turbo Coupe - Son's car
1934 Ford - My project car
dash
Quote from: FLSTCI71;157487
[SIZE="5"]WRONG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!![/SIZE]
83-4 have a unique dash. 85-88 have a newer style dash.;)
dash
I'm in texas 75420
dash
racerjc, thanks for the location info. It sounds like the dash I have is different, so it won't work for you. Sorry.
Fila, I'm not sure how my question was wrong, but thanks for the info anyway.
dash
Sorry bro, when I read it I saw did you know that ..... not do you know if. Still the info is there and you need to remember it. I wanted to use a sprot cluster till I found out I would have to change my WHOLE dash over to an 85+ style. 83-4 you have just about nothing to work with in factory form
dash
No prob Fila, like I said, thanks for the info. Hey, didn't I send you some paint chips? If so, did you ever get them?
dash
I belive you did send them, and they are in my " binder of info". Also included in there are all the Fila documents I have found, an 84 EVTM, and some info I found in the car. I like how my cars paint was not in the chips,lol
