Topic: 2.3 cam specs (Read 4847 times) previous topic - next topic
2.3 cam specs
anyone know intake / exh lift? duration? lobe center? and the cams never varryed rite? i dont think they did, just makeing sure tho :banana:
Re: 2.3 cam specs
Wouldn't a 2.3T cam be different from one in, say, a Ranger?
Re: 2.3 cam specs
i should have specified, i was refering to turbo motors. im looking into getting another tc and wanted to start some research, basicaly what i want from this is stock tc cam size, and maybe the name of a good after market cam.
edit** hears what i have so far, as you can see its some what off. like theirs sopposed to be more torque earlyier in rpm 240 ftlbs @ 3400 RPM
Re: 2.3 cam specs
Go here http://www.merkurencyclopedia.com/ and click on camshaft on the left hand side.  It will give you specs of a bunch of different cams.  Hope that helps.
Jim
86 2.3 Turbo
Re: 2.3 cam specs
thanks, one of the guys off the turbo board sent me their to that helped alot, but now im still stuck with  the above, usualy if i play around with the numbers i can get the factory or close to it rateing, i got my 2 v8's on the money with just putting in the numbers... cant for the life of me figure out y it wount "line up" with factory specs
Re: 2.3 cam specs
Could it have anything to do with the fact that you have it set as roller lifters?  I dont' know much about that stuff so I am not sure.  But the stock cam did not come with the roller lifters.
Jim
86 2.3 Turbo
Re: 2.3 cam specs
From the '84 Shop Manual:
Lobe lift: Intake  .2381
            Exhaust .2381
Theoretical valve lift @ zero lash:
Intake  .390
Exhaust .390
