Topic: Paint for dark gray bumper, belt molding and B-pillar (Read 45099 times) previous topic - next topic
Ok, I need to paint the '85 bumpers and B-pillars.
1) First, are the bumpers and B-pillars the same shade of gray?
2) What brand/part number is the best match to these Ford dark gray shades?
3) I think the '85 is supposed to have a semi-gloss sheen to the bumper gray and B-pillar (thinking of Ric's car) unlike the '87-'88 that's more a flat or satin-like black. Is that correct?
4) Has anyone used SEM for the '83-'86 bumpers and/or B-pillars?
They're very close...I would say you can probably be okay with the same paint on both, although they're technically two different codes (see below).
According to the 1983 PPG paint chip charts, under "BLACK OUT COLOR":
Flat Gray (Cougar and T Bird) - 33717
Dark Gray (Cougar and T Bird) - 33696
Now...the good news is, we have paint codes for them. Bad news is, every time I've ever checked to get them mixed, the computer at the paint store does not show a formula for either color in PPG paint. Not sure about DuPont or other brands.
Yes, except for one thing: Ric waxes his B-pillars. His shine is artificial. ;)
B-pillars are supposed to be flat-to-semigloss on 1983-86 cars. Same goes for the molding. Now to be technically correct, you should spray a flatter paint, and after it's dry for a few months, start waxing it. Eventually you'll build the paint up to the correct shine. It's better to do it that way, than start out with slightly more shine than stock, because it's difficult to knock down that kind of shine.
Yes. It is incredible paint. Unfortunately I have never found a perfect match for 1983-86 grey trim in SEM. However, that's because a) until I got this '84, I really haven't had good used stock trim parts to compare the colors to, and b) SEM paint isn't cheap, so trying out a can @ $10 each isn't very bloody fun. Now I have acquired an NOS B-pillar panel that I can easily compare to the SEM colors. I just have to remember to do that some day. I'm confident that SEM offers something that will work, we just have to find it.
You do have another option: http://www.50resto.com offers a Mustang-spec flat trim grey in an aerosol can. The Mustang grey is ever-so-slightly lighter than what was used on our cars, but it is incredibly close. I think my buddy has a can...I'll have to try it out, but as of right now I can recommend it, as it's already pre-made and ready to ship.
BTW, you can use the bumper paint on the B-pillar trim...no need to buy two different types of paint.
Thanks for the detailed reply Eric.  I just realized something.  I think I've seen '83-'86 Cougars and Tbirds with belt molding that is looks dark gray and I've also seen them with what looks like black.  My '85 actually only has faded gray on the bumpers and b-pillars.  The rest that runs the length of the car looks black.  Is that black just really, really dark gray that didn't fade because of material type, etc?  Was the lighter gray only on the LS while the XR-7 and GS got black or a very very dark gray?
All models had the same very dark grey; at least, I've never found any kind of differences between models. The fading on the bumpers and B-pillars was very common. What's on your '85 looks "normal" as these cars wear out. Now there's absolutely no fading anywhere on the '84 (and even the '86 convertible when I first got it), and I know these 2 cars were always garaged, so sun exposure has everything do to with the fading. It's not from salt or wind; it's definitely from the sun. Everything should be the same color for the factory look.
I'll snap some pix of the '84's molding and B-pillars for you tonight or tomorrow and post them up. They are about as gracefully aged as you can get, and still they show no wear or fading. Also, I'll unpackage some NOS molding and the NOS B-pillar, maybe get them all under natural light and have them all pose together.
It's good that you brought this up, Karl, because I've been meaning to find a definitive answer for quite some time now. Just never had the impetus to do so.
Quote from: EricCoolCats;156781
Ok, cool. Thanks.
Regarding the trim color, way back around 1991 when I re-painted my car, I researched this and at that time my dealer showed two different shades of "charcoal grey" for the '83-'88 cars.
It showed the same color code for the '83-'84 & '87-'88 cars and another for the '85-'86 cars.
This does make sense because when I went to ordered a replacement power antenna bezel, the parts books superceded the original '85 part number with an '87 part number. The only difference between the two was the color. The new '87 is a little bit darker shade than the original was. I used it anyway since it isn't right next to any of the other trim, and I doubt anyone would notice the difference in color unless I point it out to them.
For descriptive purposes, I would call the '83-'84 & '87-'88 color a "Dark Charcoal" and the '85-'86 color a "Smoke Charcoal".
**Edit**
Have you ever typed up a response and then 4 hours later you realize that what you typed had nothing to do with the true subject at hand?
Well, I just realized that Karl's Cougar is a GS so my experience with the paint codes on the Turbo cars may have no bearing on the color of the trim of the Gs cars.
Sorry for the interruption guys. :o
Brent
:cougarsmily:
One of 1,246 built
Brent...thanks for the confusion. ;) It's all good, I figured it was something like that.
OK, I took some photos of the NOS molding and B-pillar. Descriptions over each photo.
Here is a NOS 1987 molding. Note the nearly flat black color.
Note the part number on the box. This is as perfect as you'll ever see molding for a 1987-88 non-TC car.
Here's the meat of the conversation at hand. The NOS molding piece and the NOS B-pillar piece together. The B-pillar panel is for a Turbo Coupe, but no matter...the color is still the same as a regular B-pillar:
Closer together. Both parts had 1984 part numbers.
Oh, and ignore the packing spooge that's all over the parts. ;)
One on top of the other (they make shagy time, nyahhsss!):
My conclusion:
There's an ever-so-slight difference in color between the pieces. Otherwise they are in the same league as far as finish (flat-to-semigloss) and color. These pieces haven't seen sunlight until these photos.
If it's not storming in the next few days, I'll get some close-up outdoor shots of the '84's B-pillars and molding.
Quote from: EricCoolCats;157039
My conclusion:
 dude, you unwrapped NOS parts. Holy . Wow, thanks for digging into this one.
Eric, do you have the paint codes for the mouldings? I work in a Dupont supplied Body Shop, and can look up the codes for you. They should work, Ive looked up colors farther back than 84, and my car was fixed here, and they matched it perfectly.
Look up, it's in this thread. :)
Those are the PPG codes. I don't have DuPont or other brands' codes.
And Karl, it wasn't a problem to open those. The 1983-86 molding I'm saving for the eventual restoration of the '84.
You dont have the factory codes? I need to read the paint tag, and see what the codes are, I dont know if the PPG codes will work, I mean it doesnt hurt to try, so I'll give it a whirl tomorow.
I've never seen a factory code for the molding. It's not on the door tag. I have seen some references to it, in a Thunderbird numbers book, but there's nothing specific listed for our cars. The only time I've ever seen a number listed is in the PPG paint chip book. You have the information that I have...
Doesn't DuPont have a chip system like PPG? They might have some codes listed for trim.
