Topic: How much does a TC weigh? (Read 4093 times) previous topic - next topic
Quote from: Aerobird Motorsports;156693
The inner bumpers are already fiberglass. I've successfully drilled "lightening holes" in them without compromising strength, so there's another 10#s.
:bs:
i jus got done with this project. i figured since mine was already off, id take the free drop in weight off the nose before i put the bumper back on.
as soon as i dropped it on the scale i KNEW the 10# claim was impossible. the bumper only weighs 14.4lbs total.
a lil over an hour later my experiment showed promise. i had drilled +40 holes in the bumper with a 1.75" hole saw and it "felt" lighter.
1.6lbs to be exact. what a waste of time......
i pulled the black nose piece off and lost another pound of weight.
2.6lbs for nearly 1.5hrs of work, and it was already off the car. figure in the fiberglass shards in my fingers and it is hardly worth the effort, especially if you hafta remove it first.
i guess if you wanna ditch it altogether, you can figure 14.4lbs plus the weight of the absorbers. i dont wanna run around with an empty cover on the front, so mine will stay.
:flame:
Ted, i weighed my car last night
3,000 on the dot with half a tank of fuel
without me of course
My 84 weighs in at 3220 lbs with nothing in the tank and me not in it.
:birdsmily:
Quote from: SLEEPER T-BIRD 87;163431
Thanks guys.
How did you get it to 3,000 pounds?  This is Mustang territory.
TED
With A/C  I weighed 3,250 with out A/C and passenger seat it was3,135, both with out me on the scale(240 lbs).Have not weighed it with the k-member kit but I hope it will be in the low 3,000 range
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Quote from: TurboCoupe50;156661
Mine weighed 3560 with approx 3/4 tank of gas, mini spare, jack and probably 30lbs of tools and other assorted assorted junk... At that time I was yet to fully reinstall the AC system, but the compressor and condenser were mounted... With me the scales tipped at 3760 and I'm 200 lb, so I believe the weight to be accurate...
The '88 dealer album lists the dry TC weight at 3415 for a 5speed and 3419 for auto... So apparently the aluminum headed, tube header 5.0 only weighs a few pounds more than the 4 lunger...
you're right.  the 5.0 weighs about 40lbs. more then the 2.3t.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
Quote from: Cad-T-Bird 500;163523
Thanks guys.
TED
removed the following
tons of little brackets and bolts
rear bumper support
carpet insulation
misc interior padding/insulations
firewall pad
Auto ride control and harness
abs for a regular master/booster
engine harness/pcm/sensors
steel hood
hood hinges
hood latch
trunk carpeting
no radio or speakers
changed the following to lighter parts
hood
intake
wheels
rear end
swapped to drums
radiator
door locks
body harness
battery
things i have left to deal with/remove/swap
swap to 87-93 mustang dash
loose the dash harness
pull the seats and replace with my kirkey on driver only
front bumper supports
heater box
power windows
misc braces/metal
tubular front suspension.
my goal weight is 2,600  it can be done just dont know what it will take to get there.Ive added alot of weight in with the front mount/header/turbo stuff .
