Topic: Disconnected BCS...Slight Increase in Boost....Now what? (Read 11807 times) previous topic - next topic
Reply #75
that doesnt mean the flapper is closed.
i see you edited to add the second paragraph while i was typing, so let me add this. burning and ripped flesh is part of workin on cars. if you cant handle it, buy sumthin with a warranty. go out and do whatever it takes to find out the information to answer these guys questions. i dont care if you hafta remove the freakin turbo to check the WGA rod and flapper, jus do it.
diagnostics over the internet is hard enough w/o the owner of the car fightin the entire process by arguing and not doin as they are told. all you are doin is makin things worse, and aggravating people. get the right answers to the right questions in this thread and maybe more people would be willing to help ya out, or return to helpin you.
that is all.
Reply #76
Ok, I'm at a loss right now. I just have no idea what is what. I've seen the pictures, but the descriptions on what to do to what are just too vague for me to follow. I keep hearing to take the C-clip off the WGA arm. But I don't know where the C-clip is, nor the "Arm". I know of the rod that comes out of the WG, and then it attaches to a flat metal piece which rotates when you grab it and pull really hard. I'm assuming that controls the flapper.
Then I really get confused when I'm told to use my finger to close the flapper, and then something is not supposed to be able to touch something else? I'm sorry, maybe I'm just slow.
I was hoping to get the Air Pump and just apply pressure to the WG because that seemed so much simpler to do. Just watch to see if the Rod moved more than it should.
-DMC24guy
[/SIZE]
Reply #77
please go back and re-read chucks instructions in post  #54
follow them step by step. quit lookin for an easy way out. youre only confusing yourself.
Reply #78
Reply #79
That's a pretty good representation of how I've looked (and felt) for the past 24hours or so.
[SIZE="1"]
The creepy thing is that if I grew out my hair, I would look just like that guy...
[/SIZE]
-DMC24guy
[/SIZE]
