Topic: TC is gone (Read 6730 times) previous topic - next topic
TC is gone
Reply #60
trim panels in the isides of the steering column. and the switch panel for the ride control and Prem/Reg switch. might want the switches themselves also.
63135
TC is gone
Reply #61
trim panels on the sides of the steering column. and the switch panel for the ride control and Prem/Reg switch. might want the switches themselves also.
63135
TC is gone
Reply #62
Alrighty. I'll let you know
TC is gone
Reply #63
Quote from: gumby;155132
when are you gonna start strippin it?
ill take some pics of the locks and keys as soon as you get them all out
They are not worth pulling. You can get new fron autozone for not too much. And they sell Trubo uncut keys on Ebay all the time. But if you REALLY want them I'll get um
TC is gone
Reply #64
whats the issue? what makes them not worth pullin?
thought you didnt want any of this car to go to waste? :flame:
TC is gone
Reply #65
The fact that it's cheaper and more realiable to get new. It's up to you man. They arn't going on my car
TC is gone
Reply #66
Mike.. its so  easy to pull locks on a ford....
TC is gone
Reply #67
The first two show how much 'play' there is in the front subframe of the car.
The last pic... anyone know what that harness is for?  The one it plugs into has two wires looped back on it.  It was located behind the dash near the cluster area.
TC is gone
Reply #68
Holy Shnikeys!
Thats scary bad rust, I like how you both trust it enough to put your weight on it, lol.:giggle:
TC is gone
Reply #69
We're considering using a sawzall to remove the front portion of the car to ease getting the motor & trans out.  Considering the Ohio weather has done half the work for us, I think it's doable.
TC is gone
Reply #70
Go for it, Less work is good. :hick:
TC is gone
Reply #71
I didn't even get a picture of how the driver's side rocker is rusted through from front to back nor how the floor pan is separated from the rocker.  This car is an odd duck for sure.  Body rotted to hell and very clean interior and good-running engine... sheesh.
TC is gone
Reply #72
Don't forget how you can see through the trunk floor on the driver side. I'm all for cutting the car for the trans/motor removal eaiser.
TC is gone
Reply #73
I think the rear quarter rust is more common than strut tower.  This car's body is... as Claude said.... fuct.
TC is gone
Reply #74
Agreed. I will say the driver side is MUCH worse the the passanger side though. Not sure why
