Topic: Where to put the Tach Wire? (tach isn't working) (Read 3724 times) previous topic - next topic
I'm just gettingdone doing the alalog cluster install from the base one.  I was wondering if anyone could post pics up of where they put it.
Sam
run it out to your engine bay and off of the positve side of the coil.
Quote from: 1WLD BRD;154316
Yep, ran it through the gromit for the shift linkage, but, what's the positive side?  do is go on the green or red side?
here's some pics. i used the spiter clippy thingees but you can use wirenuts or sodier it.
have fun! i hope that answers your question
I love it when a plan comes together!!!-Hanibal Smith (A-Team)
Quote from: raser13;154321
Yep, thanks
Positive? I've always run 'em off the negative. Positive is hot at all times when the key is on, while negative is the one that pulses...
Quote from: Sduneman3;154324
Yep, thanks
Ok, tried it, and it still doesn't work.  I have it on #16, what Cool Cats, and Thundercat's has.  It's a 6 cyl, so I added a 50k resistor in parallel to the one one there, so it would read right.  I"ll take it apart, and take some pics of what I did.
Quote from: Thunder Chicken;154325
So your saying the red one?
Green wire, negative side of the coil.
Quote from: softtouch;154329
ok, that's what i did
This is what i did. (sorry for the horrible photochop)
There's the 3.8 in there till later this summer:evilgrin: , so that's why i'm trying to get it to 75k
Is there something i'm missing?
have you applied power to the red and yellow on position #1. that would stop it from working.DO NOT RUN IT TO THE POSITIVE(RED WIRE) OF THE COIL IT WILL FRY IT. i have the digital cluster with the tach on mine and it works it's on the green wire.
Quote from: raser13;154335
Yep, everything works, except the oil pressure, and the tach.  The oil pressure is becasue it needs a new sending unit (it needs the TC on right?) but i think i just figured it out, I forgot to put one of the nuts that hold it to the housing back on.  I'll try that, and see if it works
What do you mean by that?
I have mine on the neg side og the coil
