Help with the Turbo coupe. Now its fixed. Reply #15 – June 19, 2007, 04:27:45 PM I was out working on the Da Bird and replaced the plg wires. I found that number 3 wire was toast. The other all had 5k-7k ohm's resistance while the #3 was infiniti never got a reading from it. I took it out for a drive and all is well. No more missing or cutting out. Quote Selected
Help with the Turbo coupe. Now its fixed. Reply #16 – August 11, 2007, 02:20:27 PM Quote from: thunderjet302;154122Beacuse 5.0s will run ok with pretty much any wire:hick: NOT TRUE!!!! I put a set of $80 performance wires on my '92 F-150 5.0. Crossfire of 7/8 was horrendous, and in the dark, engine bay looked like it had a Christmas tree under the hood. Put the $30 Motorcrafts back on, and she runs like a dream. Use the Motorcrafts. The factory knew something when they were designed for the engine. Quote Selected
Help with the Turbo coupe. Now its fixed. Reply #17 – August 11, 2007, 02:48:05 PM sounds like some faulty wires Quote Selected
