Topic: 83-84TC tach modification - input needed (Read 8942 times) previous topic - next topic
Quote from: cougarcragar;153891
Chuck, what will you do with the "Turbo" and "Overboost" LEDs in the cluster?
It looks like a kitchen table and spray-painted particle board to me. :D
I'll make the "Overboost" light up whenever an annoying question is asked :D  Not sure yet as they just get an input to say "light"..so I dunno yet.
You are part right...the bench in the garage is painted particle board (there when I moved in), and the wood is a bookshelf top.  I do have some hardwood floors though....just most under carpet :hick:
Quote from: 84 Fila;153893
IMO I can live with the turbo and overboost lights in the cluster if I have a factory looking Tach. It's alot better then having an aftermarket one that doesn't match the rest of my int. Who ever figures this out, I wana know how to do it
OK we know....stop post whoring.....:flame:
Doing more comparisons to the 79 tach I have.  The "+" and "-" should be the leads to the tach itself.  You can see them on the PCB on the back.
Chuck taking  out the Boost over boost lights should be eazy. Then you can just use those White ones I sent you a while back. You can just take it to photo shop or somthing and take those uneeded labels off.
You know what? I have this really old little column mount tach from my first Nissan truck from ages ago. It's a V8 tach and if you take it apart, on the inside it has this little box on the input wire with a switch that says 4-6-8. I wonder if I could snip that little guy out of there and solder it into the 83/84 TC tach?
Quote from: Aerobird Motorsports;153935
Well, you'd probably have to defeat what's there to have it work correctly.  Dunno
Hrmm... Guess I'll take both apart and post up some pics.
Circuit manufacturing has come a long way in 25 years. :eek:
what happened in this situation?  I've been wondering about this mod here recently, has anyone figured out how to do this?
Quote from: 88turbo;405713
No idea.
I sent a tach off to someone, oh...4 years ago or so, for them to look at it (someone with more electrical circuitry knowledge than I had) and the project just died.  I don't remember who I sent it to. :hick:
http://www.coolcats.net/modifying/4to8tach.html
Tom that states that it specifically for 87-88.  The one I have is 83-84.
Look a little closer, Tom.  We're talking about 83-84...not the 87-88. Not the same thing.
Well thought i would post that SORRY. But from memory a resistor change is what is needed as i remember. Years back a tach had a couple of different resistors for calibration. Honestly i cant think the electronics would be different. pulses are Pulses. Sorry for trying to help!
