Topic: EVTM lottery CD give away (Read 29902 times) previous topic - next topic
Heh, I'll allow someone else to have it. I don't exactly have a need for it! Prolly shouldn't have answered :hick: :beatyoass: !
moving right along,,,,,,,,,
NEXT loto question
on the 3.8cfi , which fuel line is considered your fuel delivery line?
Remember
all views or references are always and forever described while sitting in the driver seat.
:D
The one that comes into the rear center of the CFI body?  As I recall the return leaves at an angle toward the right (from sitting in car).  Also, I think that one's the bigger of the two, plus it's right inline with the FPR.
Quote from: Ifixyawata;152566
which one is the feed,,,? i cant make heads or tails on your reply.  It looks like your talking about both of them.
no cfi fuel line came into the rear center.
im looking for a one or two word answer based on the hint.  ,, or just be more clear but dont mention the line that has nothing to do with the question.
Sorry, meant to say the feed is the one directly at the rear center of the CFI unit.  The return is the one off to the side.  I might have 'em backwards, I didn't even go out and look to cheat.
Driver side is feed. Passanger side is the return IIRC
I'm holding mine lookin at it. I'm guessing though
Alright, let me rephrase.  The FEED is more toward the center than the Return.  The Feed is actually to the RIGHT of the return.  The return comes off on the LEFT side of the CFI, from sitting in the car.
Quote from: 84 Fila;152571
nope,,, :D
Brian FTW!!! I had it bass-ackwards
Quote from: Ifixyawata;152576
yep,, BINGO,,
Answer,,,>Passanger side
and the winner is [COLOR="Red"][SIZE="7"]Ifixyawata!![/SIZE][/COLOR]
pm an addy or email me
revised at brier.net
Its interesting,, three buckeyes in a row,, yall must be some smart people.
2 of us withen 20 miles
if you already won,, you can mess with people all you want but dont answer.,,its not fair,,:beatyoass: :D
ok
next question
hard one,, might have to pull an abe lincoln and do some reading.
On a CFI setup, its easy as hell to get a gallon of gas if you need cut the grass ect.  all you do is unhook the passanger side fuel line and stick it up to your gas can.
Next you would turn on your key but only a spurt of fuel would come out.  :mad:
to make the fuel pump run as long as you want,,
WHICH WIRE DO YOU GROUND ON THE EEC TEST CONNECTOR TO MAKE THE FUEL PUMP RUN?
I know!!!!!!!!!!!! I know!!!!!!!!!!!!!! I could have won 2/3:flip: ;)
Here is the test connector if anyone wants to take a guess
