Topic: 5.0 EFI in the Fila (Read 10314 times) previous topic - next topic
5.0 EFI in the Fila
Some good advice,,, do the following
Do a compression check and toss up the numbers here
What heads do you have on now?
Intake style
Fuel pump rating
fuel pump presure
exhaust size
header type
Compression check soon
Stock ?D7? heads
E3 casting, allumnium 4 barrel intakemanifold for a 84-5 carbed mustang
Stock in tank pump on an 84
Aproxx 6PSI
2.5"
Mac equal lecnth shorties
5.0 EFI in the Fila
Quote from: jcassity;152211
Why do you think the new Boss 302 is carb'd?
ARE YOU SERIOUS?!!??
5.0 EFI in the Fila
I didn't know there was a 302 Boss that WASN'T carbureted!?
5.0 EFI in the Fila
Well as it seems I'll be starting the new buildup on the Fila motor to go in soon. My not be anything too speical or unique but better then whats in it. Any guess on power oputput from the new motor? anything over 140 and I'd be happy
5.0 EFI in the Fila
Carbs are worth atleast 20hp just as a bolt on,, cant beat that with any single EFI bolt on.
*Buzz Buzz Buzz*
  Wrong!
5.0 EFI in the Fila
Not to poop in your Cherrios....but do you actually OWN this car yet?
5.0 EFI in the Fila
In the prosess of transfering it now.
5.0 EFI in the Fila
Myself, If I were you..I'd go with the efi setup. Easier to keep tuned, better cold weather starts, etc etc.
plus, it's a  sight harder to have forced induction on a carb engine, and keep it tuned.
Not a lot of work to drop in the efi 5.0 and the required wiring to run it.
Hell, people put 'em in cars that came out before a 302 was anything more than a number between 301 and 303. :D
5.0 EFI in the Fila
Quote from: 84 Fila;152447
what are the specs?
1979 Ford Fairmont
[/B]
5.0 EFI in the Fila
As of now, the plans are...
Same E3 stang 4 barrel allumnium intake, maybe alittle porting
600 Holley 4160
GT40 heads
stock 85 cougar shortblock
Mac equal length headers
FRPP gasket kit
Factory allumnium water pump
Holley blue fuel pump with regulater
*maybe* full roller rockers used
possable MSD dizzy with MSD, if not stock duraspark
5.0 EFI in the Fila
Quote from: CougarSE;152462
*Buzz Buzz Buzz*
  Wrong!
did i piss you off in a past life or this life:D
But common,, what else can you bolt on for the price to horsepower ratio gain that compares to a carb?
Quote from: FordTruckFreeek;152429
i was comparing the NEW BOSS vs why they went with carb today instead of EFI,,, anyone wonder why they did that?  Prob because its easier to make hp with a carb and lots of it.  Its 2007 and the new boss has a carb,,hummffff,,, go figure.
5.0 EFI in the Fila
Quote from: jcassity;152554
link?
1979 Ford Fairmont
[/B]
5.0 EFI in the Fila
http://media.ford.com/newsroom/release_display.cfm?release=24698
with duel quad's:D
http://www.mustangblog.com/index.php/2006/boss-302-crate-engines-coming-in-2007/
foose put one in a 69 mach back earlier this year.  Im surprised no one remembers that.
windsor style heads????? boo hoo!!!! where is the boss relation other than the 4 bolt main block. the real boss then and now is the boss 351! the streets were pretty mean back in the muscle era.if you drove a boss 302 back then you were probably pretty low on the food chain. any z28 or 340 powered car would make your night miserable. if you drove a boss 429 you probably felt safe and smug until you stopped at that light. that big ugly road runner with the flat black hood and scoop with 440 something on it suddenly made you sweat. you decide to show him whose boss. green . you sidestep the clutch and floor that big shotgun,blue cresent hemi only to watch those sqare tail lights moving away. your first thought is how those guys at mopar are so generous with their wheelwells. those boots are big. so was the one you just got in the ass! youre a cat motoring along in your boss 351 when some bowtie hero in his new generation 70 and one half z28 starts stalking you. you stop at that same light which has been so cruel to you.you look over and its the same dude that dusted you off in his 302 z. now hes got a new version and so do you.payback time,you hope. green, you ease the clutch and stomp. he pulls on you at first,then those big canted valves do their thing. a few pulls of the flawless shifter and that chevy gets small through that flatback window. now to find that mopar!
5.0 EFI in the Fila
So about that poweroutput for the Fila guess:D ;)
5.0 EFI in the Fila
you cant guess power,, time to accept that.  it has to be measured while your building the engine with liquid and various measurements using a dial indicator, caliper with depth guage, ect.
or,,
dyno machine which uses a strain guage.
