Topic: speed limiter (Read 4570 times) previous topic - next topic
speed limiter
IS there something that hold the speed limit for example is there something you can take out of the car that will make the top speed faster a computer chip or relay fuse something
Re: speed limiter
If its a 5.0 i know that you can get a different computer...89 and earlier (i believe its those years) have no speed limiter...or you can get a custom speed chip burnt for 200 or so dollars.
Re: speed limiter
we need to know more about your car
Re: speed limiter
I just bought 2 Mustang GT speed density computers for $30.They don't have the speed limiters.
Re: speed limiter
Because going 120+ is so cool and so safe in these cars.
Re: speed limiter
its a 1987 5.0 and it has a couple of upgrades like headers and exhuast work
the engine has been rebuild no performance stuff but stock items  so if i buy a computer for an earlier model it should work because i think the most it probally goes is 85 im not shure but i never pushed it that much my dash is digital
Re: speed limiter
Your car will go more than 85mph, it's just the digital speedo that stops at 85. There is a mod you can do to your speedo, to make it go to 199 mph.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Re: speed limiter
It will go much faster than 85. I can't see why it wouldn't hit triple digits.
Nice user name, care to change it?
Re: speed limiter
But, Zach, d00d, going 155 is teh shiznit. lolololol!!!!11
Re: speed limiter
Yeah.  The engine.  Then replace it with a more powerful one.
-Jim
1987 Cougar LS 5.0
Re: speed limiter
Top speed is not the measure of a car's power, nor are you proving anything at all.  These cars are probably stable at speeds higher than 100 anyway.
Re: speed limiter
Top speed of a stock 5.0 Cougar (1987-88 body for better aerodynamics) is in the 120-125 mph neighborhood. Mustang GT's from that era did 142 mph top speed, thanks to the aero front end, ground effects and hatchback. The 1987-88 Turbo Coupe did 143 mph, again due to the pointy aero front end and back window. To get a Cougar to go that fast on the street would require more than additional horsepower. I would imagine rear end lift due to the absence of a slanted back window would be greatly increased. I know a few guys running Fox Cougars at the track; they have no problems going fast (140+ mph) but I never hear any good comments about the handling. The rear end is probably pretty squirrelly. A good spoiler at the very least would be required.
I have gone over 100 mph in these cars, on the open highway at night with no one around. Let's just say that's how I know Jeep Grand Cherokees ain't all that. ;) Probably the biggest complaint I've ever had about these cars is the inherent wheel imbalance/wobbling problem that never seems to go away. Believe me, it gets much worse over 100 mph. Otherwise it's not too bad. Emergency maneuvers in a stock car would almost certainly result in an accident/injury/death. A better handling car (wider tires, lowering, better springs, urethane bushings, etc.) would be much more stable. I wouldn't trust a mostly stock car though....too many things that could break. Much better that key suspension/steering components are upgraded first.
Re: speed limiter
You '87 Bird does not have a speed limiter.... And a '85 computer would not work anyway, all 5.0s before '86 were either CFI or carbed.
Re: speed limiter
An 87-88 Cougar V8 5.0 can do 200 Km/h ?????
  A Mustang can do nearly 230 Km/h ????
  A TC can do past of 230 Km/h (not surprise....)
  i Heard that an XR7 manual (mn-12) can do 240......it´s real ?
 Wow, i didn´t know what was the top speed on those cars. It´s nice to know that these cars have decent performance for the day.
 How much speed you can raise in a 83-86 body cougar with a 5.0 with 200hp ?
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
Re: speed limiter
Just about.  It's supposedly closer to 235kp/h or 147mph.
-Jim
1987 Cougar LS 5.0
