Topic: Teaser on one of my current projects.. (Read 6817 times) previous topic - next topic
Re: Teaser on one of my current projects..
Didn't they use the higher rate only because where they could fit the spring to the leverage of the arm?
James
Yup.  Since they had to make them a direct swap for a stick axle...the spring perches in the body had to remain the same.  They are in a LOUSY location.  The rear spring rates are close to that of the front.  That's why all the parts associated with them are so heavy and overbuilt.  Aftermarket rear springs are even heavier....
Coilover would be the best route as you already know. I had an idea of welding the subrame to the car to make it as one but I don't know if I can access everything when it is in there permenately.
James
you bring up a good point chuck, i was looking into that cobra IRS swap for a fox and thats one of the major things i didnt like about it, cauzing everything to be so bulky and comprimized. id like to look into what your makeing now, for a future car im planning on building.
We're not going to weld the subframe into the car, it will be bolted.  We are also looking at coil-overs as well.  Our control arms are going to be stout though.
We're more worried about what we want out of this and not neccessarily the profitable prospects of it.  We're aware that they might be there, but that is a secondary concern.
Nate I'am still going to put the IRS in and see how it does. From talking to people who have an IRS Cobra, they said it has a far better ride qualtiy then the solid axle. If I don't like it I will go back to the solid axle and get a watts link.
James
Now if only we could get some engineers at Ford (and GM) thinking like that...
The thing is..engnieers do think like that..but they rarely are the ones who get to call the final shots....
