Poll
How do you lift the rear of your car?
Total Members Voted: 27
Topic: Differential jacking? (Read 2948 times) previous topic - next topic
I'm gonna post a poll to see how people raise thier cars.  Now, I have ALWAYS lifted the rear of my car by jacking under the differential, then using jackstands under either the axle tubes or subframe rails.  How do y'all do it?  I'm being told that my method is terribly unsafe and I should be jacking each side separately... what the hell?
Re: Differential jacking?
I jack under the differential as well. My dad is a mechanic and he does it the same way.
My dad, too, worked a lot with cars and that's how I've always seen him do it.  Over at crownvic.net there was a discussion on this and everyone said it's terribly dangerous to use the diff to lift the car.  Granted, if you work under the car with just the jack there, you have a death wish, but for the minute or two it takes to lift the car u to get it on stands, I can't see a danger.
Same way!! Never had a problem. :dunno:  :)
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
I've always done it that way too, if my jack handle is long enough. If I'm using a small jack, such as a bottle jack or one of those $30 trolley jacks, I do it side to side. Not for safety, though, just because the eight foot rear overhang of these things makes it hard to get at the diff
ive always jacked it up by the diff. the only thing i could see going wrong other than the jack failing is the car rolling if your not on level ground for whatever reason. id never work under a car without jack stands.
the front is where it gets a little more confusing. depending on what im doing i usually jack it up on the control arms or the frame rails just behind the front wheels.
~John~
For the 8.8"(or 7.5")in a heavy car like our Birds I use two jacks, one under each side. I don't really trust the pressed in axle tubes and wimpy amount of welding. While I don't see a problem while on the jack(yea I use stands), I don't want it coming apart while I'm running down the strip due to a cracked weld. On a Stang I usually just use one jack, also the old 9" rears get one jack under the center section.
I wouldn't do it, personally.. (at the diff) but that's just because I'm very paranoid about anything involving raising a car and being anywhere near it when it happens. I'm also a little claustrophobic/paranoid once I get under there and start working. Yeah, I'm sure most would say it's a bit irrational, but that's how phobias work. :p
I back my car up on the ramps.Otherwise,I put the big floor jack under the diff and lift away,then insert the jack stands.I had all 4 corners up on stands while I was installing the h-pipe and headers.That extra 18 inches of liftcan sure make difference.
I always jack it up one side at a time, Mostly because I only have a few of the cheap $30 floor jacks and I almost never get to work on a solid surface, usually gravel.
I place my jackstands on my frameconnectors,  I still jack up from the center of the dif when i use big floor jack. If using smaller jack i do it side by side but its much faster just using the dif.
I usually use the diff as well, but on my Tbird/Cougar I have 2 pieces of 1" square welded along the rocker seam.  When I want to put the whole thing up in the air I put the jack under the door and crank one sire up at a time and place the stands out at the seam...keeps them out of the way under the car.  I would not do this w/out any reinforcement on the rockers though, you will crush them....
I should clarify, I jack up under the diff, but I don't put the stands under the axle, but under the frame rails. :grinno:
Be careful jacking the diff if the front is on ramps.  The front rolls off the pads & down the ramps, the jack rolls backward, and the whole stinkin' assemblage chases your too-fat-to-jump-up arse as you roll off the driveway & it takes a left to follow you & it doesn't stop until the jack wheels bog down in the dirt.
I drive the front up on ramps, then jack the back up at the center of the diff, and put the stands under.
