Topic: The "Stinkin Lincoln" is being striped!!! (Read 52721 times) previous topic - next topic
thanks, it didn't at first, but now it does belong here. i want to rattle can BELOW the trim ONLY cause its suppose to be blue and gray on the bottom, so the new body pecie i put on doesn't match.
Do you know how to do body work,like sanding,color sanding,etc?If not,read up on it and practice on an old hood or fender somewhere,then approach your car.You'll need to sand it and make sure everything is nice and well done,then,spray the paint (you probably won't need primer if you're using grey,black would suck),then,go back and smooth out the paint with some 1000,1500,and 2000 grit,then clear,let it dry and cure,the buff it out.To do it right can take a while,and you'll have to really mask off the car well to prevent overspray from getting on the good paint.If the paint is metallic on your car,use a good metallic dark grey,like a charcoal grey,etc.(there are many shades of grey),and use an auto paint,not Krylon or anything like that.Take your time and do it right.You'll appreciate your work,and be glad you took the time.Make sure you wet sand the areas to be painted well,and use a good chemical (whatever you like,I like the pre-paint cleaning cloths) to wipe the surface down,and a tac clothto remove the dust.Good luck.
yea i learned on my honda bike, i spent f hours wet sanding the side covers to get it somewhat decent and they still arn't that good. when i do it im gonna do it right
got a head unit, and 4 5 1/4 speakers today for freeeeee
the head unit is a jvc, and the speakers are kenwood excelon. Im downgrading the door speakers for now with them, cause my door speakers are mix matched. Now i can tell waht the sounds system is like in this thing!
Go buy a stereo installation kit so you don't have to cut the factory harness.
Looks like someone got a nasty surprise when they got off work today...
How are Kenwoods downgrading? Do you have Diamond or Alpine or something in your doors? Thats a helluva deal for free. Please buy and install kit it wires up easy as hell. And paint your car the right way. Spray can is no good unless you know what your doing, and then its not always good.
factory harness has already been raped, door speakers on my car are 6 1/2 these are 5 1/4, they are awesome speakers which is why they are going in. They came from my moms boyfriends POS jeep thats going ot the junkyard im no theif
ok so right now im saveing for suspension componants, brakes, and exausht. Anyone selling lers with flow tubes let me know. 2 1/2 only with the ball s.
im getting used front shocks to replace my leaking ones. id like ot use all new stuff but getting it going on used stuff is much better for my situation
Reply #39
still need fuel lines badly, had to move it today, lost about 1 gallon of gas and stalled it in the road, and had to jump it in the middle of the road. spun the tires up though, which royally pissed off my mom!
Reply #40
When I get back from carisle you can have my H pipe back.
Reply #41
are you serious?? what are you running for lers, and how much we looking at, ill have to start saving my pennies. If you do this man you will totally KICK ASS!! im more then happy with that h which still needs to go in, having my relative with a shop and lift help me with that one.
Reply #42
finished installing the nose, and im gonna paint the grill soon. No pics yet. saving up for the fuel lines, and rest of the exhaust so its getting there slowly!
Reply #43
What do you plan on running for the rest of the exhaust bro?
Reply #44
what ever kitzdnm is running that hes selling me
