Topic: Clear bumper lights? (Read 2519 times) previous topic - next topic
What years came with the clear bumper lights? I thought that it was 83 but while washing my 84 I found that the bumper lights say 83 on them. Are the clear ones from something older. Like say the Box birds or some other ford product? I know I've plenty of 83's with them but I'm sure that ford put them on something else. Does anyone know?
I think the story is... only some of the '83's came with 'em.  The plastic mold is probably the same between clears & ambers, so the 'casting' number might just be the same as the earlier clears.  I'm pretty sure the firewall on my car has an E3 part number, too.
My '85 Cougar had clear lights. but my buddies '83 had amber ones
Wierd... an '85 with clear lights?  I'm intrigued.  Someone on this board mentioned reproducing clear lights... I'm interested in that for sure.
Here is a pic of it:  I never put them in there, but I would have had they not been there.
Quote from: 1WLD BRD;147581
Yes, but they were Canadian cars, correct?
In the US, they were only on '83's.
my 84 had clear chuck may be right.. however my xr7's canadian and it has amber.
All 1983's and some early 1984's had clear, at least in the U.S.A. The part numbers for the amber lenses are for 1984, so any 1985-86 with clears had them purposely installed somewhere along the line. Most 1984's had amber. The amber p/n superceded the clear one.
So what you are saying is find a 83 with them in the junkyard. Damm is there anything else that might have used the same lights? I wonder if one of the Big truck lights from Peterson might work in that bumper spot. Things that make you go hummmmm!
I don't think any other Ford used that part.
Actually I'd thought about maybe putting aftermarket clear Chevy S-10 (the rounded trucks, made right before the Colorado) markers in the convertible. Never got a chance to do it...I don't know if the angles would be right either, but size-wise they're close to ours.
dunno know as much about it as Chuck and Eric, but I know my 83 has clear light! ...which happen to be busted or cracked on either side!  :beatyoass: :beatyoass: :beatyoass: :beatyoass:
Frank M.
1985.5 SVO
I've got Ambers on my '84, Switching to Clear if i can find some. :hick:
I was messing around on a smoke break at work and took a clear Peterson 426 Clear Kinda oval shaped backup light. It Looked like it would fit inside the bumper. I didn't have time to take things apart. It did look like we would have a very small gap in the very corners of the Rectagle in the bumper cover. I'm sure we would have to make a mounting braket to make them work. Besides that they are a sealed unit with only a one element bulb inside. It is also made to mount in a rubber groumet" It is a light from a Big rig trailer."  I didn't have time to look into the book to see what they had that I could order.
