Topic: Stupid *&^$*^ Squirrels!!! (Read 1782 times) previous topic - next topic
Quote from: Chooglin;147166
I also had a nest in my blower motor. I bet if you pull your fender wells out,you wil find a nest in there also............I did.
When I pulled the fenders off I didn't find any nests in the fender wells (though that was where the insulation in the blower motor nest apparently came from), but I did find a nest under the battery tray AND under the air filter housing. I got them both with the shop vac.
Aerobird Motorsports: I, too have a cat. In fact, I've got four cats. The problem was, when I moved into this house I had about 40 squirrels, thanks to the big oak and maple trees nearby. Between me with the traps and the cats with their teeth I'm down to about one or two squirrels. I trapped seven of the s in the basp00get until I found the hole they were getting in...
