Topic: 3.8/4.2L Split Port Swap into a Fox (Read 78975 times) previous topic - next topic
sorry to babble so much here jeremy, Let us know which direction you go.
Much info here:
http://www.babpen 15s.com/editorial/ar/ar90134.htm
IF I ever get the opportunity to do it:
83-86 Tbird 3.8 V6 AOD car:
Add to that:
Truck 4.2 longblock w/ 97computer for manual transmission.  That way I can mount it to an AOD and use a return style fuel system.
A bigger issue for me will be wiring up the dash and A/C differences.  Are ANY of the senders from an EEC-V system compatible with a dash from an EEC-IV system?
What I think would be neat to do would be to have the 4.2 internals...in a 3.8SC block...
But in an '88 Tbird...I mean...we ALL want to be blown AND stroked, right?? :D :flame:
Quote from: FordTruckFreeek;152025
holly snitts,, why didnt i think of that!
lol.
Quote from: jcassity;152005
Any relevant information is good information for the thread.
I've been recovering from surgeries and complications from said procedures for the past 6 months, so I won't be making much physical progress any time soon.
Quote from: Thunder Chicken;146136
Excellent info. I've always wondered if a mass-air V6 computer would work with split port. Obviously you'd need one from a DIS car (such as Super Coupe or 94-95 Mustang) as a distributor would never work with an SPI intake. The IRCM system would obviously have to be removed as well...
the 94-95 mustangs are eec-v with a return style fuel system. imo the 94-95 3.8 are junk 3 sets of headgaskets in 5 yrs.
louie  :birdsmily:
My famous last words:
Made some progress last weekend. Old engine and transmission are out.  New engine is in for test fitment.
Random findings:
Broken alternator mount
Visibly loose bolt on the oil pump
O2 signal return wire missing insulation
Also, the NVH weight on the transmission tailshaft was broken, but I've lost my camera-to-computer cable.
Pulling the old stuff went pretty smoothly except for a rounded starter bolt and transmission removal.
Upsie-daisy
Freeeee
NOT how you want to remove a tranny w/o a plug in the rear...
[Ace Ventura]Like a glove!
After I bought the SP engine and did some preliminary measuring I was worried the rear plane of the upper intake might hit the firewall and would definitely hit the discharge hose (although it will be removed eventually) and the vacuum bracket. It ended up fitting perfectly.
I still need to remove all the old vacuum lines and engine harness. Once completed I can begin figuring out exactly how to re-wire and integrate the new harness.
awesome.
I hope your documenting this besides this thread.
Im interested in the resources you got on wiring, evtm or something?
You should really go electric fan to ,, wont hurt anything.
GOOD JOB BTW,, finally someone is doing it.  That 4 eyed never saw this coming!!!
what freaking color are those CFI injectors anyway?
time to take away your paper clip code puller,,lol
[SIZE="6"]I
Hate
You[/SIZE]
:hick:
Looks good!  Keep it comin'
very cool, I would like to see how it moves out when it is done....
Quote from: jcassity;232348
Just mental notes so far. Once I get further along I'll post up solutions to the roadblocks I've found.
I bought the 2002 Helm wiring manual.
I'm going to put in an MN12 fan controlled by a DC fan controller.
Advance Auto specials that I installed after I clogged the inlet filter in my OEM pair.
Ho-ray for the ability to read engine outputs in real time w/o putting a BoB in!
What's the best way to get the engine/tranny in the car?
I was planning to remove the front clip, and install the engine/tranny together with all accessories on the engine. Will that work? Any tips?
Also, I need some kind of programmer to kill PATS/EVAP/Rear O2s/etc. SCT looks like a good buy, but I'm not sure which product is what I need. Also, will I need to get a "tune" by a third party to turn on/off those scalars? (unless I have the Pro Racer Package)
I would pull the side accesories like you did in the first pic, and I would just pull it all out at the same time. I did it with a 5.0 and an AOD, I didn't even remove the ac condenser radiator thingy. I cant remember how much of the front accessories I pulled off though.
I know it will fit with the water pump, oil pan, and timing chian cover.
