Topic: Torque Boxes (Read 6234 times) previous topic - next topic
Torque Boxes
Thanks for the input.  Going to try it with the ride control struts first.  It's very drivable on the street in the firm position and no front swaybar.  In soft it's very bouncy but may launch well.
Torque Boxes
Quote from: 5.8fastcat;143614
You will need a drag type strut up frt with like a 90/10 to help hold the frt end up, as to keep from unloading the tire after the 60 ft mark.
I got sent a set of 90/10's by accident and I was wondering what sort of effect they have on normal street driving as they come with all sorts of safety warnings on them. I was actually supposed to get the 50/50's for the rear - I wonder which would give the biggest bang for the buck considering I accidentally got the expensive struts while paying for the shocks.
Also, I am just going to make a pair of torque box reinforcements since the Mustang one's clearly aren't right. What gauge metal should I use? I was just given a brake/shear combo at work so the job should be simple enough. Also, how do people deal with the large protruding oval at the top where the top of the reinforcement is bolted to? Should I just bash it flat with a sledge and a piece of pipe?
Torque Boxes
I didn't know about safety warnings, but 90/10's would ride like  on the street. They have a super stiff bound and super soft rebound.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Torque Boxes
Quote from: Red_LX;156824
They do just fine on the street
Torque Boxes
Quote from: SLEEPER T-BIRD 87;156886
Really? Do you have them? How does the ride differ from regular struts?
Torque Boxes
Any advice on torque box metal gauge or sources?
Torque Boxes
Still looking for advice on metal gauge for torque box reinforcements and/or someone who has the name of a vendor who's reinforcements are long enough to cover the hole on a T-Bird/Cougar.
Torque Boxes
Quote from: Cougar5.0;170467
x2
Torque Boxes
Quote from: Birdman;170508
Not exactly what you are looking for, but a start.
http://www.wolferacecraft.com/detail.aspx?ID=294
These will help along with the boxes.
I get the feeling that they are looking to have people weld in that plate and weld up the torque boxes without adding the typical reinforcements. I wonder if that plate would fit on a Fox Cougar?
Torque Boxes
Those plates will fit your cougar, as they fit my TC just fine.  Also, even before you weld in reinforcements, you should weld the seams.  I'm using them with the wild rides boxes, and everything is okay so far.
88 TC, Lots of Mods.
