Topic: 6.14 Gears (Read 4616 times) previous topic - next topic
6.14 Gears
You're wanting to do a lot of work just to spin the tires.That can be done without any work or money.
6.14 Gears
with my around 320's hp 351w and nine inch on 225's its scary trying to get it to hook, it will rost them in first and second with the t-5. Only time till the t-5 takes a shiznit though. pos soft gears
6.14 Gears
If/When I swap to a V8 T5, I'll probably put in some 4.10's to make the .6:1 overdrive a little more livable...
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
6.14 Gears
Quote from: daboss351;142766
With my mustang, i wish i had like a t-56 so i had the second overdrive
Take a second look at the overdrive ratios. The T-5 actually has a numerically lower OD.
6.14 Gears
t-56 would give me allot more strength, and i like the thought of 6 gears over the 5. That t-5 is not meant for the torque produced by that 351. You can feel it. its not gonna last very long once it starts getting driven more
6.14 Gears
wow i seriously almost fell off my chair when i saw the thread title.
6.14 Gears
4.10 Gears are awsome, I had them in all my 5.0L LX coupes.  I could do 3rd gear brake torques with ease.  Like has been said first gear doesn't last long though, but if you have sticky drag tires, you can pull the tires off the ground at the track, with minimal mods. ;)  at least in a Stang you can.
6.14 Gears
Okay, now for install.  I have never took trac-lok apart.  Is it difficult to place 4.10's in my mercury?
6.14 Gears
Quote from: Ether947;142779
You sure?
t56's as put in Camaros and Firebirds had a .5:1 sixth gear (that's why those  things can get almost 30 mpg on the highway)...I know the T5's fifth gear was not that low.
Garrett H.
Exhaust sound clip
Another clip
6.14 Gears
Quote from: Red_LX;142933
You sure?
Guess not.
http://www.corral.net/20anngt/trans.htm
