Topic: Rockford Fosgates? (Read 6993 times) previous topic - next topic
Rockford Fosgates?
I was planning on put the speakers all six speaker spots. but my question is once I see there's the quick connect in the door slot. but is it really that simple or more complicated. and whats the best cd player I can buy without all the flask but has good performance quality. :hick:
[SIGPIC][/SIGPIC]86 COUGAR LS 5.0 stock. Soon to be project "Cheetara"
85 Ramcharger 318-727 "Big Girl"
Rockford Fosgates?
I can answer one question.. by being a customer.
Pioneer makes a BADASS headunit. The DEH series is remarkable.
The mosfet 50x4 DEH-1800 is what I have. I like it alot its only about 100$
Rockford Fosgates?
I will have to check it out. But have you put speakers in your door unit.
Rockford Fosgates?
It's not hard to put speakers in. When I did my sonys in the door, I cut off the quick connects from the factory and just put ends on them for the speakers. Not sure what your asking
Rockford Fosgates?
what i am asking was if i get speakers for the cougar willl I have to mod anything.  like for instance "no company makes quick connect speakers anymore" or will I have to do the same as you cut them off and crimp them to the speakers.
Rockford Fosgates?
no crimp... solder.
Rockford Fosgates?
I admit it, I crimped it.... I don't have a sodering iron.... yet:hick:
Rockford Fosgates?
Yeah man, I got 6.5" Clarions in the doors. sounds real nice. you might have to drill a hole or 4.. and use self-tapping sheet metal screws... but its well worth it.
Rockford Fosgates?
i like and prefer pioneer decks but ive never used anything else other than an alpine. i hated the alpine. it got replaced quickly with a pioneer.
ive always had the best luck snaking all new wire to all the speakers. i dont know, i just feel better about it and feel its the right way to do it.
try not to buy cheep speakers....
~John~
Rockford Fosgates?
I got stock tweeters, Sony Xplod door speakers, Pioeeres in the rear and a single 10" with sub
Rockford Fosgates?
run new wire... it sounds better.
Rockford Fosgates?
I'm running MB Quart all around (Autobahn series up front, coaxes in the back, 10" sub in the rear). They use stiff materials that give them a really tight, punchy sound, which suits my musical taste (70's-90's rock, not much big, booming bass). I've heard that MB Quart was bought sometime in the last few years and quality has suffered, though. If I remember, Rockford Fosgates of a few years ago used to use more resin in their cones than many other manufacturers, which gave them a similar tight, punchy sound.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Rockford Fosgates?
Crutchfield.com has the proper adapters for the doors, dash, and back. They are very much universal between the different types of vehicles. That way you don't have to worry about messin anything up.
1987 Cougar XR7 5.0 SOLD
1992 Ranger 4.0
2018 Hyundai Elantra
2019 Ram Rebel
Rockford Fosgates?
Hell i appreciated all the advice, because I don't mind working on machanical things but I'm no fabricator and even worse at at anything electrical.
Rockford Fosgates?
I suck at wiring, but I basicaly wired the whole motor when it was CFI, did ALL the wirign underhood now for carb, and the sterrio now. Not much at all but I'm learining as I go
