Topic: fuel pump swap (Read 3187 times) previous topic - next topic
fuel pump swap
in parallel with the motor i meant to say,,,, that way you maintain the voltage.  I get stuff bass akwards sometimes.
anyway thats how a lot of variable speed dc motors work.  Similar to the AC motors with a frequency drive instead.
Was'nt the cams from that era provisioned for a mech fuel pump still ? 1985 CFI would put him in the earlier years castings.
My cam has a spinner ring for lack of a better discription .  Even my old 3.8 was provisioned for a mech pump but it had a lobe instead.
fuel pump swap
My car is an 84 with cfi.  It has just a  low pressure fuel pump in the tank.  I believe they are rated for 38-42 gph @ 6-8 psi. It works fine with a carb.
