Topic: Alignment specs? (Read 1457 times) previous topic - next topic
Alignment specs?
All,
Thanks so much for the answers I've gotten so far. This board has been a life saver in some spots. :)
I'm putting a set of Maximum Motorsports C/C plates in the car, and obviously am going to take it in to get aligned after it's done. However, I can't find any good information on what to ask it to be set to. Anyone have a suggestion?
Alignment specs?
For daily street use... 1/16" toe in, .75 to 1 degree negative camber and 2 to 4 degrees positive castor (I think 4 degrees was the most I could get out of my plates).
Alignment specs?
Mine only go to 4 degrees positive, all the way back.
Matt :tg:
Alignment specs?
From the '84 Shop Manual:
For T-Bird/Cougar
Caster nominal +1 degree, minimum +1/4 degree, maximum +1 3/4 degee.
Camber nominal +1/4 degree, minimum -1/2 degree, maximum +1 degree.
Toe-in nominal 3/16 in, minimum 1/16 in, maximum 5/16 in.
