Topic: I'm bored so I'm building a model replica.... (Read 2387 times) previous topic - next topic
That nose look awesome.
I always used solder to make headers. It's perfect for it. I think you'd get pretty frustrated trying to work with aluminum, too hard to make the tight bends you'd need.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Vinnie, that is bad-ass. can't wait to see it when it's done!
I'm working on a custom F-150 right now, let's just say it's gonna have forced induction cough cough S351 cough, and a couple other little goodies, MY spin on what the first gen Lightning SHOULD have been from the factory ;)
Thanks guys.As far as bending aluminum,there's a trick to it.Fill the tube tightly with salt.Yes,salt.Then,heat the tube (salt won't burn up),and bend the tube.the salt keeps the tube from kinking up.Now you know.I'll take pics as i get work done.I want it to look as real as possible.
Quote from: vinnietbird;140621
Actually, with real headers, I've read that you can bend tubing for custom headers using sand and heating the pipes.:D
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
Yep,same concept.It's worked well for me with my other kits I use for competing.
Nice!:headbang:
Resident "Idiot".
Quote from: Big_D
If you insist on doing it the hard way, be my guest...
headers made from solder look plenty realistic. if I remember this weekend, I'll get pics of some I made and you can judge for yourself.
Garrett H.
Exhaust sound clip
Another clip
Pics would be nice.I know aht I know,and I'm always open to try something different.Let me see what you have built.If they have the look I'm going for,I'll give it a try.I have to keep everything scale,so,thin solder is a must.It has to look like I shrunk my car whan I'm finished.I went and bought an aftermarket distributor kit with blue wire.I found some super fine mesh for the cowl vents.It's going to be an insane build.Plus,I need a break from my Project Pheonix for a few days.It keeps me focused.
Wow! That sounds pretty cool! I'm actually about to do the same thing for my car! I haven't started it yet though, just took it out of the box and examined everything so far. I'm gonna need a 5 litre for mine too and some wheels and I'm gonna try and get that shaker on it to....although, it doesn't sound like I'm going to the extent you are going, I don't think I'm quite that talented. Good luck and let us know how it's going!
Well I do know a thing or two about detailed models...
Although, I built that one in high school so it isn't perfect (plus it was the first fully detailed model I built so stuff is missing/wrong). I also realized I used way too much black after I built the thing, so it's hard to pick out some details due to a lack of contrast.
I used 1/8" aluminum tubing for exhaust pipe on that truck (works out to a scale 3" pipe). Polish it up and it looks really nice.
If you can find some 1/16" solder, that would be a perfect size for scale 1 1/2" primaries.
Making everything appropriately "to scale" can be tough sometimes...
Garrett H.
Exhaust sound clip
Another clip
i did something similar once i took a chevy bel air model, and a supercharged big block from another and had a stock bel air with a weland blower out the hood, came out so nice, and then it was dropped and the body cracked...
I won 3 plaques in Texas at the show they had in march.One Master award for the engine in my '70 Torino kit,and first and second place in my class.The Torino has everything from throttle return spring,vacuum lines,plug wires,opening doors,and trunk,poseable steering,seatbelts,etc. etc.The daytone I just finished has all of that with pop up headlights,opening everything,etc.I have to have my T-Bird replica looking like pics of the real car.i need to post some more pics.
