Topic: What cam do I have (Read 3104 times) previous topic - next topic
What cam do I have
May I suggest the comp cams grind # XE250H (part # 31-230-3). It's here (just scroll down a bit) http://www.compcams.com/technical/Catalogs/106-07/64-71_230.pdf
It's got very close specs to a stock HO cam and with your set up should give you some where between 260-300 hp. I'd also try a bit smaller carb something in the 570cfm range. You may not need a 650 with basically stock 5.0 parts and a cam.
What cam do I have
300 ponies with heads, cam, intake & exhaust when that cam is essentially an HO profile?  I honestly doubt it.  You're talking about bolting on over 150 horses.  I'd believe 260, but not 300 without some sort of power adder.
What cam do I have
Quote from: Ifixyawata;139894
Actually with good heads, Tbody, intake and exhaust system, 300hp with a stock HO cam is no real feat... MM&FF got 245hp, out of a completely stock HO with just the dyno headers as the only mod...
What cam do I have
There's no reason to get rid of the AOD.  Especially if your gonna maintain this car as a street vehicle.  You will need a different governor in the tailshaft along with a shift kit.  I'd also recommend a higher stall convertor and a trans cooler.
Right now I really do prefer the torque. Would a truck cam ( non roller 5.0) be an idea for that then, since trucks keep it lower in the rev range?
That's pretty much what you have in there right now.  Perhaps the duration is a little different, but the lift #'s are the same according to references I've seen.  I can't see it being that much different.
Quote from: Thunderjet302
That oughtta wake her up some without going nuts with the revs.....
What cam do I have
Quote from: TurboCoupe50;139923
Forgive me I stand corrected.
What cam do I have
Box stock GT40's wont do it though. Maybe some aftermarket heads, but not a factory cast GT40.
What cam do I have
They'd come close... With some exhaust bowl/port work, piece of cake...
Biggest issue is getting it tuned correctly... Most aftermarket backyard combos have another 20-30hp hiding...
