Topic: Exhaust system...X or H? (Read 5842 times) previous topic - next topic
Which type of exhaust system should i get for my cougar? H or X pipe? I figure im just going to do the exhaust till i can get an engine swap. So far i've heard that 3' is too much for the stock cougar (dual but single is ok) engine and 2.5 is best (for dual)...any opinions? Also, WHICH ones specifically (ones that would fit a 93 mustang?) should i get?
Re: Exhaust system...X or H?
depends on what you want for the engine. will it be supercharged, or turboed?  x is better unless you have forced induction because of the increased exhaust pressure the x eventualy acts as a pinch point, with a h pipe, it just skips the eq. tube.  im running a h pipe because i plan on a supercharger.
Some X-pipes will not accommodate an AOD transmission.
I have an '88 Sport with an AOD and a Bassani x-pipe. Sounds awesome.
Man, if I'd have known that X-pipes fit around an AOD I would've gotten one.
Ihave a Bassani X on my 87 XR-7 along with 1 5/8 mac shorties,Ravin lers and Dynomax (modified) tailpipes. I picked up 3 tenths just from the X pipe swap back when I was running stock stang headers & stock tails. Also - sounds like NASCAR not like every mustang on the road. Big plus in my books.
Quote from: Ifixyawata
Don't be too sad. The ler shop had to modify the x-pipe to get it to work on the driver side (due to the transmission). H-pipes = just as cool.
-Bryan
If state emissions might ever be a concern for you, go with the H-pipe - an X-pipe will not be able to accomodate catalytic converters. Or so my exhaust guy told me before he cut out my X-pipe  :mad:
1984 Cougar Convertible
1988 Cougar XR-7
most of the companies I've seen offer with or without cats on an x-pipe.I went without on mine but there's lots of room for them.
Yea, you're probably right but I'm going on the word of the mechanic who did my exhaust. Who incidentally drove a Grand National and guaranteed that I'd be selling my T-Bird someday soon  :moon:  Probably just a Ford hater who was trying to mess up my ride  :mad:
Nah just kidding, but I do remember him saying there were clearance issues with the AOD transmission if you had cats on an X-pipe (not necessarily that they won't fit, but setup concerns, etc.), so it may be worth looking into just in case.
1988 Cougar XR-7
My x-pipe came from bassani with 2 cats and since then I have had to replace the cats. I passed CA smog tests in August without a hitch. The car originaly came with 2 cats, so when the smog guy looks under the car and sees 2 cats then everything is as it should be according to him.
Just dont get a MAC H-pipe. I wrestled with mine for around 4 hours trying to make it fit! Nice quality, poor fit... I heard the BBK's fit much better as far as budget pipes go.
http://www.cardomain.com/id/dogcharmer69
Hah!  I got the cheapest one around!  My Summit H-pipe went in seamlessly without any fighting or anything.  Only $109 too.
I had a Bassani x-pipe on my 86, fit perfect. :banana:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
bassani x is definitely the way to go. I could actually feel a seat of the pants difference when I swapped out the h-pipe for an x-pipe on my '74 F100
