Topic: Cold water under dash? (Read 1325 times) previous topic - next topic
Hiya guys, sorry if this is in the wrong place. On my '85 TBird when making right turns I will occasionally get a few cups worth of cold water  dump out from under the center area of the dash. This has been going on for a few weeks now.
 If it helps, it's the 5.0 Elan and the heater is disconnected.
 I am hoping this is something common and trivial, or at least an easy fix. I just can't figure out where it would be coming from.
Thanks in advance.
1985 T'Bird 5.0
1987 Cougar 3.8
1992 T'bird Sport 5.0 HO
Sounds to me like some left over coolant is left inside the heater box. Also it sound like the drain to your system is pluged. Just take a coat hanger and poke it out. Also maybe you have the pluged drain and it is just AC condensation
Hadn't considered that, make sense now. Thanks!!!
1985 T'Bird 5.0
1987 Cougar 3.8
I started getting that when the AC is on last summer. Where is the drain located?
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Look on the firewall, passenger side.  It is a little black tube thing.
yes the little black rubber tube thing under the A/c Dryer(can looking thing with hose going into it) Should be eazy.
