Topic: Explorer heads (Read 5764 times) previous topic - next topic
Explorer heads
hey vinnie, so you said that you will sell the GT40 heads right? if they are the true GT40 (not the gt40p's)  i'll buy them from you!
Explorer heads
GT-40P heads actually out flow the regular GT-40 iron heads. The chamber is actually a better design. The only down side is that the FMS headers require *slight mods* to the stock motor mounts:hick:
Explorer heads
does anybody know if i could use the GT40X tubro swirl heads? or if i could use the ford racing b-303 cam shaft with a AOD?
Explorer heads
If you get anything more than a stock HO cam, you must change the pistons.  The SO has flat tops and they wont clear the valves with a bigger cam iirc.
Explorer heads
Quote from: quicksilver;138172
Basically if you want to do anything more to the engine than a stock HO conversion or use TW heads then you need to change your pistons. If you want to run a B303 with an auto you'll need a higher stall torque converter and a trans cooler.
Do a little research and see what combos make the power you want. Don't always go for the bigger is better mentality. All this stuff costs $$$$$ so be sure you get what you want. If you want to do anything other than stock a stock HO conversion YOU NEED HO PISTONS.
Explorer heads
You'll need at least a 2400 stall torque convertor.
Explorer heads
e 303 was for the auto's
Explorer heads
How do you tell GT40s from GT40Ps by looking at them?  Also, I have a Mustang Kmember, and urethane mounts, will I have clearance issues?
Matt :tg:
Explorer heads
Gt-40Ps have have GTP stamped on the head under the valve cover as well as GTP at the front corner of each head. The plugs stick out much straighter than standard Ford small block heads as well. You shouldn't have a problem putting them in as you have a Mustang K member and mounts. The swap headers should fit no problem as they were designed to clear the Mustang mounts. I had to cut a little bit out of my drivers side mount for the FMS headers to fit but I have the stock T-bird mounts.
Explorer heads
Reply #39
It's [FONT="System"]ONLY[/FONT] the [FONT="System"]'86-UP  SO[/FONT] engines and all '86 HO(also '87 in LSC) engines that have flat top pistons that have valve clearance issues... All the earlier engines [FONT="System"]HAVE[/FONT] valve reliefs, though they probably arn't large enough for some aftermarket heads and cams...
[FONT="System"][SIZE="5"][COLOR="Red"]GOT IT????[/COLOR][/SIZE][/FONT]
Explorer heads
Reply #40
My engine has the forged flat tops.It's from an '87 LSC originally.
Explorer heads
Reply #41
Quote from: TurboCoupe50;139408
Bumpin' to the top...
Explorer heads
Reply #42
thats a sweet picture turbocoupe50!!!
Explorer heads
Reply #43
*should* have a set before the week is out if it stops this rain/cold shiznit. I'll keep posted.
Explorer heads
Reply #44
If you get the *P* heads make sure you get the FMS stainless shorties for them. They fit around the plugs great and since you have an '84 they won't hit the mounts.
