Topic: My Wife is Going to Kill Me!!!!!!!! (Read 2984 times) previous topic - next topic
Quote from: V8Demon;136861
Well, before she does, tell her I'm looking for a used Mustang or Cougar.:hick:
That has a possibility of happening.  To do so would require bigger injectors.  I can do that later as it's real easy to swap injectors on these newer Mustangs as opposed to a 5.0 (no pulling upper intakes)
I'm not up to date on the 3V  4.6s. How much boost can you run on an otherwise stock engine before it begins to turn the exhaust into a parts bin?
A Paul are you putting on yourself, need help. Curious to see how that gets installed.
I'm gonna have Joe over at Mustang Magic tackle this one.  I simply don't have the time for a project like this.  I could do it, but 3 hours a weekend would put me to being finished sometime in 2009......
Here's how it's done.  I think I've figured out a way to use my aftermarket intake as well.  We'll see.....http://www.modularfords.com/articles/S197_JDM__Saleen_Blower_Install/1.html
Good power boost but don't expect to eat any GT500's. Or do you have other mods to go with it?
Exhaust is already done and also lower control arms.  When I threw the intake tube on and reflashed the computer with a tune for 93 octane, I got over 30 RWHP just from the tune & intake.  A dyno tune as opposed to using the program from Saleen is good for about 20-30 HP extra.  The car should run 12.2-12.3
Oi, that's shagy.  I love the blower whine you get from posi displacement blowers.  Anywho, good luck with the intake issue, and be sure to show the Cougar some love as well.
Update:  I ordered some motor mounts that will drop the motor 1/2".  It has been proven to add clearance where it is needed the most for these blowers....along the firewall.  Hopefully it's the answer to my intake tube issue as well concerning hood clearance.  Between that and a couple of other things I should be able to use my JLT tube WITHOUT heating it up and distorting it.  This is something that hasn't been done yet as far as the no distortion part.....Wish me luck!
