Topic: IRS update (Read 4674 times) previous topic - next topic
IRS update
Quote from: 1BadBird;136896
gumby, the springs I used are AFCO springs. I bought them from a "roundy round" shop. I almost bought 800 #ers but thought that they might be a tad too much.
Chuck: how's those mounts coming?? No rush :D
Depending on what you're using up front, the 800# springs in the rear should be fine.
I haven't had a chance to finish up the upper part of the mounts yet....working on it though ;)
IRS update
ah, more good spring info! i love spring info. are they jus standard stock car springs?
good to know ive got more options w/o having to decipher aftermarket sn95 drop spring ---> fox bird ride heights if i dont like the 750# rate on these 00R springs ive got, or if they dont balance well with my 400# front c/o's.
IRS update
The wheel rate for a Cobra IRS spring is 33% of the actual spring rate in the stock location.
If you're using coil-overs, the wheel rate is 50% of the actual rate.
So those 750# stock-location springs are 247# at the wheel (800#'s are 264#)
Your front 400# coil overs are 360# at the wheel and the same as 1440# springs in the stock location.
IRS update
33%, eh? good to know. i knew the liked ALOT of spring and understand why with the location of the spring on the arm, but i hadnt come across a figure in any of my readin yet.
i knew the front c/o was roughly 90%.
IRS update
i knew the IRS likes ALOT of spring, and i understand why with the location of the spring on the arm, but i hadnt come across an actual figure in any of my reading yet.
IRS update
went and did some searchin on the almighty CC.com. i found it stated in a couple places that the rear IRS rate should be near 5% less than the front rate for good chassis frequency.
for now my car will go together as is, but in order to get to 5%, im gonna need to either raise the rear rate(1050-1100), or drop the front(275-300). guess ill know after i get it on the road.
IRS update
Chuck, that's some good info to know about the spring rates. I choose the springs I have by going from MM's spring rate for their sport spring rate, i went with the middle rate. The next one was listed as a Race spring. I too will see how the car sits and rides, of course after I do get the thing running.
Take your time Chuck, not in a hurry to put the engine in yet.
gumby, have you thought about checking the 05'+ shocks to see if they have the rebound /compression lengths that would work with our cars?? I had heard that they would fit but haven't checked it out myself yet.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
IRS update
Cool :D
IRS update
i havent considered s197 shocks at all. i dont think the lower eye bolt hole is big enough for the stock IRS shock bolt.
plus ive got these 04 cobra shocks and struts sittin here :evilgrin:
IRS update
I need to get some shocks so let me know how those 04's fit, ok? Oncw my wife finishes her Nursing school in May, look out parts suppliers! :evilgrin: Who knows, maybe I'll get the beast going by next spring. :D
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
