Topic: I BOUGHT THE LINCOLN (pics page 5,7) (Read 15684 times) previous topic - next topic
Reply #90
axle tag says (i went and pulled it off)
S407f
3L27N88  7G21
The three was right on the edge of the bolt so its half messed up i barley can see it, so i have a 327 trac lok right!
Reply #91
Yes you do!
3.27 Locker 8.8
At least the tag says you do. could have been changed over the years but I doubt it.
2TN88 = Date Code, yours is an 88 yes?
I belive I was wrong on this info previously.. seeing the order of things now
3L27N88 7G21
this "88" is not indicating year but ring gear size.
Reply #92
yep....3.27 trak loc.
That was the first thing I checked when we test drove our 89 MK VII Bill Blass.  I took it down the road, power braked it and instantly smoked um and what a wonerful sight in my rear view mirror.....  2 stripes.:D  Yes mine has 3.27 also.
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
Reply #93
Cool,now you know you can scratch gears off your list and get on the other stuff.
Reply #94
yea i got some grade 8 bolts to make the strap work, and now its raining!!! I need to get the retainer clips for the fuel lines and then the tank will be in the hole!! First thing to be bought new for the car is gonna be filter rp oil, plugs and wires cap and rotor. Hopefully my dad is sending enough for that.... Then im saving for my new 2 1/2 h-pipe. Any of you know how you get the side trim on?? i need to get it back on it looks py without it!
Reply #95
Ok i got the fuel lines on the tank all the wireing and the vent hooked up, drill the hole for the bolt, hang the straps stick the tank under, jack it to the floor, pull over the straps, AND THEY DON"T REACH!!! Upon further inspection the straps say for a ford thunderbird, is this my problem? If i take the plastic shield off, the straps fit but VERY tightly. I need input, cause i want this sucker in TODAY!
Reply #96
Heres some pics ive never seen a tank installed in one so i might have it in wrong please god tell me im doing something wrong!
Not sure if anyone here can help but im just shooting this out there!
Reply #97
Get the Mark VII straps.Do it right the first time.Don't "rig" it.
Reply #98
Mark Vii and thunderbird have the same gas tank and straps i just found out on the lincoln forum, so thats not the problem.....
Reply #99
O.K.,I commented before I saw the pics,they hadn't loaded yet.That looks right,you just need a longer strap it appears.I can check at the boneyard next saturday unless you can find some locally.
Reply #100
Nevermind then.Can the tank be slightly moved a little?Can you pull the strap a little more?It looks like there's some slack in there.
Reply #101
i think something is off i mean it just doesn't seem right..... im fitly covered in rust chips and getting frustrated so now im cooling off before i go outside take it all down and go threw it again to make sure its right. If only i knew what right was.
The straps don't fit to the tank or the cover remember in those pics theres no plastic shield, so without the shield its no good anyway. i think i might have to shift the tank over one notch im not sure. Im waiting on input from LoL.
Reply #102
Quote from: daboss351;139981
Yup, I swapped a '86 LSC tank into a '87 TC, same stuff... Well I did have to swap the gage sender...
Guessing maybe you have straps for a earlier Tbird with the 18 gal tank...
I should still have a set of perfect strap's from a '87 Sport, I can measure them if you'd like...
Reply #103
I had someone measure the straps on his mark they are the same size so im pulling it all back down and taking it slow to make sure i didn't mess anything up. Hopefully it will be in when i get back!
Reply #104
G'luck...
BTW I got 35.5" measuring on the outside of the strap...
