ho converion help
Reply #1 –
Just buy the Mark VII engine and get the computer.You're good to go.If your car is a 5.0 car already,that is.If you can get the engine cheap enough,just drop it in if it's running,swap the computer and exhaust,and call it a day.It really is that easy.Otherwise,you'll need the upper intake,cam,heads,throttlebody and spacer,computer,fuel injectors and some time and gaskets.It would be a lot quicker to just swap the engine,though.
