Topic: SBF RACE part blowout (Read 1800 times) previous topic - next topic
Set of moroso solid mounts for SBF in fox chassis including block plates.
Like new $50.00
Canton Race pan for 302 fox chassis
Needs repaired (welded were rod punched a hole) usable with a little work in otherwise good shape includes pickup that also needs repaired
$100.00
FMS 9 way adjustable Timing chain
Low miles still like new complete with ARP cam bolt
$60.00
NEW 302/351W timing cover
Complete with water pump ultra low mile also has chrome fuel pump block off plate.
Ford motorsport harmonic dampner
OEM replacment not chna made junk. Like new.
$60.00
ARP dampner bolt
Like new with washer 5/8 12 point hex
10.00
Torque starter
Oem 93 cobra unit (rebuilt) works as new
$75.00
P/A SFI c4 to SBF bellhousing
Performance Automatic has developed the Pro Fit Bellhousing for Ford engines. This unique housing is cast from a high strength aluminum alloy and is SFI 30.1 certified. What makes this bellhousing so unique is that it is part of their Pro Fit System. This bell is CNC machined to accept the 157 or 164 tooth flywheels and starters thus eliminating any guesswork. A case fill or pan fill C4 transmission can be used with this bell and all hardware is included. Want to change to a Powerglide? Using the same bellhousing, just add the Performance Automatic Pro Fit Ring kit and the Powerglide is a direct bolt on. Maybe a Turbo 400? Just buy the ring kit for the 400 and bolt it on!
$275.00
TCI SFI Flexplate
# SFI-Approved Flexplate,SB-Ford 289-351C, 351M-400
# 50 oz. Balance
# 10-1/2'' Bolt Pattern
# 157 Tooth
$60.00  Like NEW
PA Nitrous converter
stalled 2,600 behind my weak 306
Like NEW super low mile
$375.00
289/302 Performer RPM Air gap (matched to 1262 fel pro) some plenum work Like new
$175.00 (235.99 in jegs)
Msd Billet distributor for 289/302 Steel gear almost brand new.
$150.00
Scorpion 1.6 roller rockers,3/8 stud like new low miles
$150.00
Complete 3" exhuast for fox mustang
289-302 fox chassis Bassani SS 1-5/8 long tubes,slip colletors,T bolt clamps,Ball and socket joints,X pipe and 2 chamber flows and dumps
$650.00
Set of underdrives for 5.0
Powdercoated black NICE
$65.00
5.0 bracket set and tensioner to run alternator ONLY
comes with belt
$50.00 or buy the pullies also and Ill make a package deal
Set of panhandle ported Canfields
Supposed to be stage 2 ported  (looks nice) 2.02 1.60 valves
58cc chambers 3/8th studs,guide plates,Triple springs,Bronze guides etc LOW MILE
Needs one intake and one exhaust valve
$1,300.00 OBO
Stuff needs to go to fund new project.
nothing fits my 351
The underdrives should, I think.  Wish I had the cash.....
Oh, yeah, bump.
351W in the works
Quote from: bhazard;300566
You got woman'd.
Quote from: daboss351;135358
nothing fits my 351
ive got a set of Canfield 212cc heads ported by panhandle performance also:D
im afraid to ask what you want for those, but im curious so how much
i knew i was afraid i wish i could but as it is i need to fund flat tops, roller cam, machine work, and odd and ends to get the car going, thats WAY out right now, unless i hit the lotto then ill let you know
  Can you post pics of these?  I've been looking to re-do my exhaust and would like to see what these look like.  Also what size collector are they and will they fit an AOD?
Quote from: V8Demon;135540
I dont have any pics yet there actually still in the car I can get some Though there real nice fitting headers
There a 3" slip collector and my car had a C4 so id imagine it would also clear the aod
New items added!
DAMMIT!!!  Here we go again. I really need that hi-torque starter, but it's gonna be a few weeks before I can do it. trying to buy a parts car right now.
ill give you a 93 escort for the heads lmfao
Any offers?
heads,rockers and valve covers SOLD
needs to go
