Topic: Type 6 (86+ 5.0) Poly Motor Mounts (Read 90479 times) previous topic - next topic
Reply #90
Wow I am glad i saw this, I was gonna swap in a mustang k member to get rid of the factory style mounts. I will definatly be getting a pair when I get to that point!
2015 Ram 3500 MegaCab Diesel
1986 Thunderbird Elan 302 Crate, x303 heads, e cam, 24lb injectors, gt40 intake, WC T-5, TC rear w/ 3.55 gears, CHP control arms,cobra r wheels.
Reply #91
i hate to ask but how much is a set of mounts for the 86 5.0
86 t-bird 226k miles and blown transmission
Reply #92
Quote from: kwellst;258053
$175/shipped.  Have some sitting here.
Reply #93
I have been endeavouring to keep all of my mounts onhand and available for shipping.  Worst case delay is 2 weeks if I get stuck w/o bushings between orders.
This applies to all mounts for the 86-88 cars (2.3T, 5.0, 3.8).
Reply #94
Plenty of mounts available.
Reply #95
Do you have any on hand still?
Reply #96
Right now I'm waiting on some more bushings, but should have them with in a couple weeks.
Reply #97
Do you have anything vert worthy for an 85 5.0?
Reply #98
Quote from: daminc;288717
Jerry,
As far as I know you can make use of the "Mustang" type mounts for your '85.
Reply #99
Thanks Chuck, I'll look into that
Reply #100
You still gonna have any of these mounts available?/ won't be ready to purchase until 1st of the new year!! (2 kids and x-mas and all) but i am definately gonna want a pair
Reply #101
Of course.
Reply #102
Hey Chuck. Someone said that these mounts raise the engine a bit. Is that true? My 351w will sit higher already and I don't want it to sit ant higher. Also the soft and stiff bushings, which would be better for a 400 ft pound of torque engine?
:burnout:
Reply #103
Well, they might raise the engine compared to old/blown-out stock bushings, but they should be the same as a set of new stock-type mounts as far as height goes.
Stiff for your application.
Reply #104
Chuck
Do you have 87 88 mounts on hand if you do how much shippped to 64062
87 TC
