Topic: OFFICIAL Fox T-Bird/Cougar REGISTRY thread, 103 Total now! (Read 29290 times) previous topic - next topic
Reply #45
Parts cars I have the info on:
Year: 1985
Make: Mercury
Model: Cougar
Trim: LS
Original Engine: 5.0
Original Trans: AOD
Paint Color: Oxford White
Interior Color/Material: Scarlet Red cloth
VIN: 1MEBP92F3FH615256
Options: Premium Sound, Dual Power Seats, Luxury light group (engine compartment light, dual-beam dome/map light, instrument panel courtesy light, dual illuminated vanity mirrors, illuminated entry system), Power Windows, rear defroster, interval wipers, tilt wheel, speed control, power lock group (power door locks, power decklid release and power fuel filler door release), Rear Defrost, carpet floor mats
Door Tag Codes: unk
Radiator Tag Codes: unk
Had something large and heavy land on the left rear and squich it completely. Also awaiting said crusher. Last one for me for awhile...
Reply #46
Eric,
When we gonna see the Vert on here? Or the Top 25 for that matter
Why, are you starting a convertible registry? Because I've already got one of those going on. ;) I don't publish information about the 'vert like that...it's a personal thing, no offense. Far as the Top 25, it wouldn't even crack it so why publish how slow it is. :(
Reply #47
Wow! Eric's so slow he's #26 out of 13 cars :D :hick:
I understand on the Vert info though.
Reply #48
Year: 1988
Make: Ford
Model: Thunderbird
Trim: LX
Original Trans: AOD
Paint Color: 9Z/91 tutone code C (Silver Clearcoat Metallic/Smoke Clearcoat Metallic)
Interior Color/Material: LG Smoke Gray/Leather (60/40 split consollete)
VIN:1FABP62JH******
Options: (over Base T-bird) Keyless entry, lighted door locks, autolamp/autodim, cornering lamps, lighted vanity mirrors, engine compartment light, Leather wraped steering wheel, cruise control, floor mats, power parking brake release, full digital dash with multi guage and trip minder, interval wipers, power windows, power locks, dual power mirrors, dual power seats with power recline, Premium Sound with EQ, power antenna, Electronic Climate Control, rear defrost, power trunk release, power fuel filler release, 10" rear drum brakes, front license plate bracket.
Door Tag Codes: Body 63D, Paint 9Z/91C, Trim LG, Axle 8, Int Trim HD, MFG date 9/87
Radiator Tag Codes: long gone
Also I have my mostly intack build sheet. If any one has an 88 Bird I might be able to tell you the code for some options.
Reply #49
I have a few birds floating around, but I'll have to come back and update my entries as I have the chance to check on some details.
Year:1987
Make:Ford
Model:Bird
Trim:Sport (former DD, now future parts car)
Original Engine:5.0
Original Trans:AOD
Paint Color: 26 Bright Red Hi Solid Clear
Interior Color/Material: AD  cloth/ Scarlet
VIN: 1FABP61F5HH121XXX
Options: Dual power seats, auto dim, auto lamp, towing package w/ 10" drums, keyless entry, premium sound, ATC, illuminated vanity visors, corner turning lamps,trunk release, power mirrors and door locks, power antenna, non TC door panels, power windows, cruise control, premium sound, rear defrost, tilt steering, flash to pass
Door Tag Codes:  build date: 12-86, GVWR: 4470, DSO: 42 Cleveland, Paint: 26, Int. trim: AD, Radio: H, Axle: M 2.73 locking, Trans: L -AOD
Radiator Tag Codes:missing
Year:87
Make:Ford
Model:Bird
Trim:TC (parts car)
Original Engine:4 banger w/Turbo
Original Trans:T5
Paint Color:26 Gright red hi solid clear
Interior Color/Material:Red cloth
VIN: 1FABP64W4HH177XXX
Options:ATC, dual power seats, power mirrors, power locks, keyless entry, auto lamp, auto dim, premium sound, illuminated vanity mirrors, corner turning lamps, trunk release, power antenna (will double check other options)
Door Tag Codes:TBA
Radiator Tag Codes:TBA
88 TC  57,000 miles!
1FABP64T0JH153XXX
2.3l T4
  Door Tag:
Build date: 12/87
GVWR: 4448
DSO:
Paint: 26 Bright red hi solid clear
Int. trim: FH  leather/ ?  (dark grey outer, light grey inserts)
Radio: H am/fm stereo/ cassette, electronic
sunroof: B sunroof glass
Axle: W 3.73 locking
Trans: A4LD
options: pwr moon roof, dual pwr seats, pwr mirrors, pwr door locks, pwr windows, pwr antenna, ATC, premium sound, auto dim and lamp, rear reading lamps, dual illum. vanity visors, trunk release, rear defrost, keyless entry, illum. entry, cornering lamps, tilt steering
87 LX  only 23,000 miles!
1FABP6231HH18XXX
3.8l V6
  Door tag:
Build date: 5/87
GVWR: 4323
DSO: 14 Pittsburgh
Paint: 5W  Light Taupe hi solid clear
Int. trim: KE  cloth (split bench)/ Taupe
Axle: 5  3.27 conv.
Trans: T  AOD
options: column shift, pwr driver seat, pwr mirrors, pwr locks, pwr windows, TC door panels, illuminated entry, dual illum. vanity visors, rear defrost, tilt steering, cruise control
87 TC
1FABP64W2HH140XXX
2.3l T4
  Door tag:
Build date: 2/87
GVWR: 4350
DSO: 22  Charlotte
Paint: 14  silver matallic hi solid clear
Int. trim:  FH  leather/ ?  (dark gray outer/ light gray inserts)
Axle: K (?)
Trans: 2(?)  T5
options: non ATC, premium sound, cruise control, tilt steering, pwr driver seat, pwr windows, pwr mirrors, pwr locks, no illum entry or keyless entry, no pwr antenna, rear defroster
88 base
1FABP60FXJH134XXX
5.0l 302
    door tag:
build date: 10/87
GVWR: 4470
DSO: 17 Washington
Paint: 31 Medium Regatta Blue Metallic Clear
Int. trim: HB  cloth (split bench)/ shadow blue
Radio: F  am/fm stereo, electronic
Axle: 8  2.73 conv.
Trans: T  AOD
options: buttstuffog cluster, column shift, pwr locks, pwr mirrors, trunk release, cruise control, non ATC
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
Reply #50
Warbird9,
Get those paint colors and I'll add your two to the list.
thunderjet302,
Added you, and I do believe you have the only factory leather consolette car I've ever seen.
Reply #51
1984
Thunderbird
Turbo coupe
2.3T
5spd
Gray paint unsure of the code can't read the tag on the door frame. I do kow that the name is blue somthing. I even matched it up to a paint chip from 84 and it was blue something that matched inside the door frame no sun fade in that spot.
Gray leather interior
1FABP46W1EH
 P.W. ,P.L. ,Cruise ,Tilt ,A/C, power dirver seat, keyless entry, prem sound, Power mirrors ,auto headlights, lighted entry,
The door tag is unreadable.
Need to locate the Rad tag it used to be in the glove box but its not there now.
Not sure what you can do with this info . I do think it's strange how I have so much power stuff but no rear window defog.
Reply #52
Year:86
Make:Mec
Model:Cougar
Trim: Ls
Original Engine:3.8 ( Now 5.0 EFI
Original Trans: AOD?
Paint Color:Black/silver 2 tone ( Need to check)
VIN: 1MEBP9237GH629958
Options:I'll know in about 3 weeks
Door Tag Codes:"    "
Radiator Tag Codes:"  "
Reply #53
ipsd, you have a pic of the paint? I'll be happy to help.
Reply #54
How come you dont have the Thunderbird's Sport package listed?
Reply #55
Cause nobody with a Sport has posted yet???
Reply #56
Ah.  Well, I'll go get my numbers here in a min.  Then we'll have a Sport up there :) .
Reply #57
Ok uh...I just wrote down every single number shown on the door tag (where my VIN is) and this isnt matching up.  My interior color should show a BL somewhere, but nowhere in my numbers is there such a string (this car has never been tampered with).  I dont even know where to start.
Reply #58
LOL, OK, your VIN doesn't have the paint or interior codes in it. Take a pic if you can...
Reply #59
Yeah, I know that.  I have EVERY number written down off of that tag.
Int Trim: EE
There also is a letter H thats kind of in between the "Tape" and "R" labels on the sticker.  Not sure where it's meant to be.
Ax: M (I know this means it came with the 2.73 rear end)
TR:  T55KK
body:  63D
GVWR:  447C    LB/2027KG
Front GAWR:  2276 LB    1033KG
Rear GAWR:  2246 LB    1G18KG
VIN:  1FABP61F9JHxxxxxx
Then next to the VIN number is a half closed box with a few numbers:
F0060
R0033
22
