Topic: 5 lug rear conversion issues!!! (Read 2985 times) previous topic - next topic
Well then you got a pretty good deal for $150.
The gear ratio won't be "right" for a 2.3T though.
the housings arent any wider just the axels also, the housings have been preety much the same from 79-98 fox cars,
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
what are the common gear ratios for those years of stangs?
Quote from: cougarman;133342
He has an 86 with a 7.5, which IS different and wider than the others (the housings).  The overall width from axle  to axle  is the same however.  This has been discussed ALOT on here.
i am going to change the bushings on the rear control arms. Are the bushings the same from a 86 to 95 ?
The SN-95 bushings are a bit stiffer.
will the stock drive shaft bolt up to the 8.8?
