Topic: bonivelle ssei (Read 1421 times) previous topic - next topic
bonivelle ssei
Ok my friend bought a 94 bonivelle ssei, its the v6 supercharged, but today once the car goes into drive soon after it starts to drop idle, and the dash starts flickering, then it stalls out. He just bought the thing and is flipping out. anyone on here know anything about this thing? This is a first step on trying to figure this thing out. He also said the check engine light is been going on and off. any input would be nice
bonivelle ssei
Check the NARP lash and adjustment!
(sorry, couldn't resist!) :hick:
bonivelle ssei
Pull codes
bonivelle ssei
thats what i thought only problem is the car stalls out in drive, and isn't registered so its gonna be hard to get to a parts store. any other way to pull codes? and im pretty sure all then narps are pristine man, he got the supa titanium ones, they good for like 400 extra hp man!!!
bonivelle ssei
idk, but the 92' in the garage is a betch to work on thus far.. and ive only started work on the brakelines.
bonivelle ssei
TCCS is bad .
unplug the connector on the front of the transmission facing the radiator.
bonivelle ssei
seriously its that simple? now leaving it disconected gonna ruin anything?
bonivelle ssei
Quote from: daboss351;132871
Yes,it may set a memory trouble code but it will not effect anything except freeway gas milage as it locks the torque converter to drop engine rpm on the freeway to improve gas milage it is common on gm products for it to be faulty.Will it hurt the car? Not at all
The connector may be blue or yellow ive seen a few clear its not hard to find and will have 2-4 wires coming from it.
bonivelle ssei
thanks he swore if he couldn't fix it he was gonna destroy the car cause hes a moron and after he just payed 1200 i don't wanna see him kill it
bonivelle ssei
Ok it was a alt wire shorting out, but now hes telling me that it won't shift from 2nd to third, any ideas on that we are gonna pull that little plug just to be sure too
bonivelle ssei
There is a test connector under the dash on the drivers side. It has two rows of six terminals.
With KOEO jumper the two terminals on the upper far right.
The check engine light will blink the codes.
Do not start the engine with the jumper on.
