Topic: possible donor rig (Read 1994 times) previous topic - next topic
possible donor rig
ok all i have found a 91 sc tbird with an HO 5.0 and autosmatic. the car is trash it was a ricers attempt to make a tbird into a honda. there is wires all over the place and the person that had no freakin clue how to fix a car there is an intake leak and it needs all the gaskets not to mention what ever else is needed so this motor and tranny ive offered 25 bucks i pull do i need to walk away slowly or do i take it?
possible donor rig
Take it now.It's easy to convert it over to use in our cars.New gaskets,and swap the accessories from our kind to that engine,as well as the upper intake swap.easy stuff.
possible donor rig
swap the accessories? and whats this about the upper intake?
possible donor rig
The upper intake on a '91 is different than an '86 to '88.The accessories are different than the '96 to '88's as well as far as how close they are to the engine.they may work in a Fox body,but I don't know.
possible donor rig
k but the fox bodies look like they have a lot of room under the hood and the motors wouldnt set that high on em would they?the routing on the belt looks pretty close to what we got on our rides
possible donor rig
Like I said,the accessories may work.But the upper intake is different,and doesn't fit our throttle and TV cables.There's plenty of room for it,but it just isn't worth using with the mods that have to be done when you can just bolt on a Mustang H.O upper and call it good.
possible donor rig
k sounds good thanks
possible donor rig
If it's an SC why does it have a 5.0 in it?
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
possible donor rig
Swap maybe?
possible donor rig
The accessory brackets will work in a fox.  The person known as "MywifesKitty" did it.  I would assume the brackets would bolt up to an older style block without a hitch.  As shown in the thread he swapped the whole motor.  http://www.foxtbirdcougarforums.com/showthread.php?t=10085
possible donor rig
thanks for the help yall will be gettin a hold of the motor hopefully soon thats kind of my plan is take the motor and accessories this way i dont have to dick with the conversion of anything major.
possible donor rig
ok all im needing to know what all im gonna be gettin into ive been talkin to wifeskitty and he sez that the swap includes a ton of splicing anyone else to the swap on an 87 with a 3.8? any write ups would be a major help does coolcats have anything?
possible donor rig
ok stupid question time. for the whole cougar thing can i just replace that with bird? just makin sure the under hood is the same on both.
