Topic: Bumper installed pics! (Read 3277 times) previous topic - next topic
I actually did raise them about a half inch from where they originally were...because when I installed the bumper cover the lights were pushed against the bottom. Now they just barely clear it and I have a little room to adjust them, so it works.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Driving lights rock.  Best lighting upgrade over stock fog lights. I wonder if my Hella FF75's could support higher wattage bulbs. Theyre 55W.
Yeah the stock fog lights suck IMO, I had mine wired for the 100W bulbs and they still didn't throw any useable amount of light.
BTW if the lights you have are aftermarket I'm sure they could run 100W bulbs. As-purchased, these ones I had came with 55W "super white" bulbs (which I hate). I found the "yellow" (actually dichroic) ones that are in there now on ebay, bought them assuming that they were 55W but they turned out to be 100W. I didn't change anything with the wiring, the 100W bulbs have the same size power wire running to them as the 55's. I have em running through a relay anyway so I wasn't too worried about it.
Garrett H.
Exhaust sound clip
Another clip
that looks pretty freakin' sweet.
way too COOOOL!!!!!!!!!!!!!!!!!!!
