Topic: Help!! falls on face at 10psi (Read 2185 times) previous topic - next topic
Quote from: turbo86xr7;130295
i have a autometer boost gauge hooked up. It just starts to pull under boost and then falls down. I dont see how timing would do that. it should still rev past 3000 rpm. Without getting into the boost it will erv way past 3000:punchballs:
What is your plug gap?
It is not that i dont want to listen to your advice i just want as many ideas as possible when i attack this thing.
Quit fishing for ideas and actually try some of his advice, chuck knows his stuff.
Also check your fuel pressure.
Scott
Plug wires and plugs are were I would start.Use only factory style plugs,turbo's dont like platinum plugs. I had a problem with my car cutting out when it got warm,I was told tfi,map,ect but no fix. The only thing that fixed it was a simple plugs,wires. Did I say "plugs n wires."
1999 Trailblazer(wifes rig)
Chuck is right - you need to have the wastegate hooked up. You'll blow something up, otherwise.
When I first got my '86, it would start choking and shaking under WOT past 3k RPM, just as yours does. I did a full tune-up with Motorcraft parts and it changed everything. The car ran MUCH better after the tune-up.
Are you hearing a whooshing sound WHILE it's building boost, i.e. when it gets near 10 psi? Could be that boost is blowing out around one of your couplers, but it's not enough to actually blow the coupler off. I've had that happen a few times when I didn't tighten the clamps enough, it'd start to leak around the coupler once I got up near 10 psi or so.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Chuck was right. the intake hose was sucking shut. the last thing i checked:bowdown:
The stock hoses have a wire in them to keep from collapsing.
What did you do to rectify it?
mine didnt have a wire in it?!?!?! oh well it gots one now:punchballs:
