Poll
what cars the best: thunderbird / cougar / mark VII
Total Members Voted: 16
Topic: Questions about Automatic transmissions? (Read 1591 times) previous topic - next topic
What type of transmission does a 84 mercury cougar w/ a 3.8L V6 Tfi have? whenever i floor my car while in the drive gear from the speed of 20 to about 40-45 it makes a grinding sound until i let off of the gas. what is the problem and what could be needing fixing from this question?:cougarsmily:
main shaft striped maybe?
Your transmission is either C5 (three speed ) or AOD (four speed with overdrive).
P-R-N-D-2-1  C5 selector.
P-R-N-D-D-1  AOD selector.
 Don't know what your problem is.
Quote from: blackcougar71;129929
Could you amplify on your symptoms? If its a AOD you only have this problem in Drive or in Overdrive too? What's the transmission fluid like?
:dunce:
Could have a gearset failure. Get a high contrast towel, white will do, wipe the dipstick onto the towel. Any contamination? Smell burnt?
Quote from: softtouch;129945
Wouldn't the selector for AOD be:
P-R-N-O-D-1
:dunce:
Have you identified where the sound is coming from?
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
i dont have overdrive and the sound is coming for the front of transmission. my transmission is a c3 i know.
my selector is p-r-n-d-2-1
