Topic: Valve cover (Read 2275 times) previous topic - next topic
Valve cover
Yeh but my pcv is in the bottom intake.I was wondering if I was suckin oil out to the tb.from the cover.It's more of a ? than a problem.Maybe to see what others have done.I had this ? for days no one wanted to answer till I brought it back up.
Valve cover
Questiong and problems get lost in other threads sometimes. Sorry about that bro
Valve cover
Theres no need for apology.This is where people learn.
Valve cover
Quote from: kitzdnm;130118
You dont quite understand how the PCV system works. The PCV valve is located in a place where it can suck air from the crankcase. In a 5.0, it in the lower intake. It sucks air from the lifter valley, which has airflow access to the crank case. Generally, when the engine is at low throttle and mid throttle, the PCV is open, and sucking air, keeping fresh air in the crank case, helping keep the oil from foaming, and helping keep the rings seated. This fresh air comes through the throttle body, to the valve cover, through the heads, and into the crankcase, which then it gets sucked into the intake manifold. It keeps fresh air going through the crankcase, while not creating a vacume leak.
The issue is with moderate and WOT, the PCV valve closes, and the only area that creates suction for the crankcase is the throttle body. Since the rockers sling oil around, and you have no baffle in the intake manifold, youre getting oil in your throttle body. If you ran a baffle, a catch can, or maybe even a little fuel filter, you wont have issues.
Keep in mind with the filter, if it gets saturated, it wont flow for shiznit.
Valve cover
Nice write up.But what baffle in the intake are you talkin about/
Valve cover
By the way I do understand  positive crank preasure.
Not to be an Idiot I was wondering if there was a better way.
Read your own words when WOT the valve closes?,then what?
suck it does>TB.It's not a problem I can see but more of a ?
So far I don't see a real answer.
Valve cover
Quote from: kitzdnm;130146
At WOT, the PCV valve closes, and it uses the suction from the throttle body to relieve the pressure, and create vacume in the crankcase.
Baffle in the intake? I was refering to the baffle in the valve covers. If you take your stock valve covers, flip them over, youll see a baffle under the oil fill tube. Thats to keep oil from slinging up to where it can get sucked up by the throttle body.
